Author Topic: Minis For Sale on BAT  (Read 252576 times)
Offline vizcat
Re: Minis For Sale on BAT
« Reply #2225 on: November 19, 2021, 09:22:20 AM »
One of the brake rotors is badly scored, either it's down to the metal on the pad or they stuck in a new set and didn't bother to machine the rotor......any way you cut it it will need brake work too.
The best thing I can say about it is that it doesn't seem rusted, and the body looks original, but the resell red respray didn't do it any favors, with over spray everywhere and lots of Edd China's satin black on everything else. This is definitely a "spritz and flip" car.
Resell Red is right! I had to adjust the saturation of red on my monitor so that I could try and look at the paintwork without going blind.
Offline BruceK
« Reply #2226 on: November 19, 2021, 10:16:25 AM »
1992 Honda Beat (JDM)
Offline Jimini II
« Reply #2227 on: November 20, 2021, 01:09:25 AM »
That S race car with the funky vin number looks very well built and prepared.
Offline BruceK
« Reply #2228 on: November 21, 2021, 09:25:29 PM »
A Cooper S from Oz is now on BaT.   Iím not familiar with all of the unique features of the Australian Minis, Iím sure someone will chime in with comments if things arenít right.
https://bringatrailer.com/listing/1965-morris-australian-built-cooper-s/
« Last Edit: November 21, 2021, 09:27:27 PM by BruceK »
Online MiniDave
« Reply #2229 on: November 21, 2021, 10:20:00 PM »
Well, thanks to exposure to Mark's Saucy Aussie there were a couple of things I thought looked wrong - there are no hoses going from the rear fittings to the hydro units to charge them, and it looks like it might have coil springs instead  - but it's hard to tell from these pics.
Also, it doesn't seem to have the depressions where the wiper arm holes are in the scuttle.
Mark will have to chime in on the door handles too....
Offline MPlayle
« Reply #2230 on: November 22, 2021, 09:26:10 AM »
The rears are definitely coil springs.
I would think the fronts are effectively "rigid" since they are not interconnected and the fluid has nowhere to move.
There is also almost no space between the rear coils while the car is in the air for the pictures.  I would think it almost certainly encounters coil binding while being driven.
Online MiniDave
« Reply #2231 on: November 22, 2021, 09:53:50 AM »
Fronts are the same as the rears....there are no hoses going to either, in the rear you can see the fittings to charge the system but there aren't any hoses attached to the fittings, like they've been cut off.
Offline MPlayle
« Reply #2232 on: November 22, 2021, 10:53:52 AM »
You are right, the fronts appear to also be coils.
I was mislead by the hoses running from the breathers to the fenders and the light greenish tubes/pipes under the car running from the fittings at the rear to the front of the car.
Those hoses from the engine breathers should be going to a "gulp valve" and on to the carbs.  Instead, they appear to be going to the fenders for atmosphere venting?
Online MiniDave
« Reply #2233 on: November 22, 2021, 10:57:17 AM »
Yep, looks that way to me, tho I don't remember Minis of this era having the gulp valves, only Sprites and Midgets - and only from 68 on.....but I could be wrong.
Offline tmsmini
« Reply #2234 on: November 22, 2021, 04:05:09 PM »
My first Mini, a 66 S had the gulp valve.
The car was delivered in California if that makes a difference.
When I got it in 72, I had to have it smog checked which basically meant removing the valve cover cap and see if the idle went up(maybe down?)
Offline Brit_in_TX
« Reply #2235 on: November 22, 2021, 04:20:43 PM »
New Mini on BaT.  A JDM one thatís missing bumpers and has a roofrack and a 998.  Canít see this one going too high.  Maybe $10k - $11K?
Edit: the import paperwork shows the purchase price was under $2800 (!).  So either the buyer got a real bargain, or maybe the importer lied to the feds and falsified the customs paperwork.   In either case, some mental gymnastics are needed to justify a 300% or more increase over that for bidding.
https://bringatrailer.com/listing/1990-rover-mini-cooper-3
You were right on your estimate - $10900
Offline BruceK
« Reply #2236 on: November 22, 2021, 05:48:38 PM »
Lucky guess!
Hereís another JDM Mini just listed on BaT.   Iíve never heard of anyone calling it a ďfour-speedď model. Thanks
How is it this highly non-original car (which is frankly not that impressive) was acceptable for BaT and Michaelís car was not?
https://bringatrailer.com/listing/1993-rover-mini-2/
Offline LarryLebel
« Reply #2237 on: November 22, 2021, 05:57:21 PM »
It does have a Cooper badge and LED headlights.
Offline gr8kornholio
« Reply #2238 on: November 22, 2021, 07:39:17 PM »
Yes, it appears to have always been missing the wiper indentations from the resto photos.  Other is is the under body tray is missing.
The 65-68 Aussie floors are unique. Found that out when dan was trying to line up a patch and nothing seemed to line up.
Now the boot lid indentation is correct along with the door handles and the two holes in the drip rail at all 4 sides.
So maybe a previous owner didnít bother to source patch parts from oz and just put the uk ones on.
Online MiniDave
« Reply #2239 on: November 22, 2021, 07:59:10 PM »
Steveston Motor are good guys, if that's their car - they do some really terrific Mini work up there in Canukistan.....
Offline Jimini II
« Reply #2240 on: November 22, 2021, 09:50:45 PM »
What are your thoughts on the Aussie S non vented sills?
Are they original or of course may have been replaced but I see a patch on the one side.
Just for the fact that an Aussie S has roll up and vent windows it would be my choice over a Brit S.
Offline Jimini II
« Reply #2241 on: November 23, 2021, 09:56:29 AM »
Looking at the video in the listing for brakes they used 7.5" S brakes with a clutch master that comes with a .75 bore, no proportioning valve, 1/2" wheel cylinders and Mintex shoes and pads.
A weird combination but he says it works well but I think I would prefer a dual split system from a safety aspect.
Offline BruceK
« Reply #2242 on: November 23, 2021, 10:25:55 AM »
AndÖ yet another Mini has popped up on BaT.   Itís a Clublman with the boring combo of a 998 and a slushbox.
Got a feeling someoneís gonna buy it for a VTEC swap.  Then again, with the auto itís the perfect car for a non-Mini person to get a Mini.  But the Clubman front end hurts the cute factor.
My guess is that it will be bid to around $10K.
https://bringatrailer.com/listing/1979-austin-mini-4/
Online MiniDave
« Reply #2243 on: November 23, 2021, 01:27:10 PM »
The color and RHD aren't doing it any favors either, I'll be surprised if it goes over $8K, but Bruce seems to have the vision on these prices!
Offline Jimini II
« Reply #2244 on: November 23, 2021, 06:56:11 PM »
A lot of these earlier automatics seem to have been owned by older people and have been used sparingly with low miles.
The top side of this car looks a lot better than the peeling paint on the bottom of the car but it does not look like a rust bucket.
Offline Jimini II
« Reply #2245 on: November 26, 2021, 05:24:24 PM »
A Moke from Oz is on BaT.   Wonder how it will do compared to an English one?
https://bringatrailer.com/listing/1971-leyland-moke-californian/
Blue Aussie Moke sold for $18k.
« Last Edit: November 26, 2021, 05:27:06 PM by Jimini II »
Offline Jimini II
« Reply #2246 on: November 26, 2021, 05:25:57 PM »
Offline BruceK
« Reply #2247 on: November 29, 2021, 07:59:07 PM »
Sold for $37,250.
Offline cstudep
« Reply #2248 on: November 29, 2021, 10:01:31 PM »
Sold for $37,250.
Looks like it was RNM at 37,250.
Offline BruceK
« Reply #2249 on: November 30, 2021, 10:00:55 AM »
Sold for $37,250.
Thanks for the correction. I wonder what the reserve was?
