The manifold gets too hot for locktite to hold, even the red version melts at about 400*, I double nut the stud to tighten it into the manifold.
If you're going to use antisieze use the copper stuff as its higher temp rated, I just use brass nuts, however those studs are metric and I haven't seen any brass nuts in metric.....but if you can find them they won't rust/corrode to the steel studs.
Edit: a quick search shows plenty of brass nuts in metric sizes - I noticed Porsche uses copper nuts on their exhaust sytems
