I think I know the answer, but figured I would ask.
My LCB header has a bung in the "V" of the outer two pipes which is really close to the exhaust port (circled in red), I believe this was factory for SPI cars. Most of what I've read says it needs to be further away from the exhaust ports probably in the 2 into 1 collector (marked with an X)
So can I run it in the existing hole or do I need to weld in a bung at the "X"?
