I noticed today when trying to eliminate or reduce the 'creaking' rear anti-sway bar that my alleged 'heavy duty' Maniflow rear bobbins had sheared and my rear box was essentially just danglin' in the breeze.
So now I'm wondering - what's everybody else using at the rear to hold your rear silencer and tailpipe in place?
I'm toying with the idea of cutting the remaining stud from the rubber block, drilling through the rubber and fitting a bolt through the rubber. This will allow the rubber to dampen vibrations, and having the bolt running through will prevent shearing the rubber block in the same way that the MiniSpares middle exhaust mounting (C-19G3257) is constructed.
