Author Topic: My 65 Australian MKI  (Read 83301 times)
Re: My 65 Australian MKI
« Reply #650 on: July 13, 2022, 10:43:56 PM »
Do those use sleeved lug nuts?
Reason I ask is that Don got rid of a set of Revolution wheels because he could never get them smooth - we figured the sleeves didn't allow the wheels to stay centered. Since he went to the mambas with tapered lug nuts he got rid of all the vibrations
Offline gr8kornholio
« Reply #651 on: July 14, 2022, 10:29:51 AM »
It doesnít say specifically but from the picture and the lugs they show they appear to be using the angled seat nuts.
Yea, my original issue with current wheels was the sleeve style lug.  Yea the holes had wallowed out, thatís why I had inserts put in, but now the wheel needs balanced off the lugs and no one does it.
« Reply #652 on: July 18, 2022, 10:17:05 AM »
Got the car registered again today.  Glad I got there early.
Also got a message the wheels are ready to ship but of course they have no spacers and have no eta on them.  So guess Iíll wait for them to come in and see what exactly is an issue.  If I still need them I can get from minispares.   And the fronts donít need them so I can drive for now with mismatched if the rear does need them.  Set to go to upholstery shop the 26th to do the seats.
« Reply #653 on: July 21, 2022, 06:31:35 PM »
Tracked down the non working signals from the inspection.  Bad flasher.  Got a close enough replacement from Napa and have turn signals again.
Wheels are scheduled for delivery tomorrow.  Either will be yay problem solved or o 🤬 still a problem.  If I need spacers for the rear Iíll put in an order from ol UK for stuff.  Lol.  Fingers crossed.
« Reply #654 on: July 21, 2022, 07:37:05 PM »
Do you already have the spacered out rear drums?
« Reply #655 on: July 21, 2022, 07:43:23 PM »
Yes.  Didnít realize how far the coilovers stick out compared to just shocks.  If I didnít have the spaced out drums my current wheels wouldnít have fit.  So Iíll probably have to get longer studs than what comes with the spacers cause they have to go through the drums too.
« Reply #656 on: July 22, 2022, 05:28:25 PM »
Got the new wheels today.  Look good.  Question though, how much clearance should I go for between the tire and the rear coil over spring?
The tires are on the verge of rubbing so I want to move them out, but not really any more than I have to cause I like how they look.  I figure 3mm is cutting it close so maybe 5mm if not that itís all the way out to 3/8Ē which is pretty much 10mm.
« Last Edit: July 22, 2022, 05:30:36 PM by gr8kornholio »
« Reply #657 on: July 22, 2022, 05:43:57 PM »
Fronts or rears?
Front wheels move out as they go up, just FYI.....I think 3/8" clearance is more than enough....
« Reply #658 on: July 22, 2022, 05:45:44 PM »
The fronts clear fine, itís the rears.
So youíd go with 3/8 (10mm) over the 5mm?
« Reply #659 on: July 23, 2022, 12:53:17 PM »
So according to several other car forums this is a large topic.  Almost all are in agreement that if there is space itís enough.  So will go with 5mm.  Enough for good clearance but not going to push them out any noticeable distance.
« Reply #660 on: July 23, 2022, 06:32:19 PM »
Nothing like spending $800 to find out you still have an issue.
Not a total waste as the wheels look better and I needed new tires, but the frustration of well whatís causing it sucks.
« Reply #661 on: July 23, 2022, 06:43:07 PM »
« Reply #662 on: July 24, 2022, 11:52:59 AM »
Some times you just need a 2x4.  Exhaust I guess wasnít far enough back.  Also the knuckle bolts were really loose.  Iíd checked them at the beginning but I guess they loosened up.  Not sure how they are the nylon nuts.  Guess something to keep an eye on.  Maybe getting a new header as the knuckle put a deep gash/dent in one. Doesnít look cracked or anything but will see.
Anyways the damn rattle is gone.  Feel a little  :-[ though as guess this should been first place to look.
« Reply #663 on: July 24, 2022, 12:19:35 PM »
Hey so it's fixed!?
« Reply #664 on: July 24, 2022, 01:34:02 PM »
Sounds like it.  Ran it up to 60 twice and no noise.   Only thing now after banging on exhaust my afr gauge just says A1.  Need to look that up now.
« Reply #665 on: July 24, 2022, 01:39:49 PM »
I just had to buy a new sensor after melting the wires on exhaust. All it would say was A1. Even soldering wires back together wouldn't fix it.
« Reply #666 on: July 29, 2022, 01:57:59 PM »
Seats are off getting done.  Smashed a fingernail working on the interior.  Minispares and dhl seem to be back on their game.  Ordered last night and itís shipped and so to arrive Tuesday.
« Reply #667 on: August 01, 2022, 08:44:46 PM »
Got my stuff a day early.  Yay.  Got the spacers in, 5mm was plenty. Did have to replace the studs though so yay extra work.
Also put the chrome trim around the bottom lip of the shell.  Wasnít to bad with the heat gun.  Didnít like the bend coming off the rear as it had been rolled up the wrong way for a couple years now.  Sucky part is halfway up the side, the easy part, discolored.  Like seriously.  O well.
« Reply #668 on: August 01, 2022, 09:06:44 PM »
The car is looking great! Once you get the interior back, where's the first place you guys will take it for a run?
My stuff came today too - won't get started till tomorrow tho - really hot out now - really!
« Last Edit: August 01, 2022, 09:08:24 PM by MiniDave »
« Reply #669 on: August 01, 2022, 09:32:23 PM »
Yea, the heat definitely limits the time in the garage.  Working outside the car isnít bad, but climbing around the inside and getting in and out really wears on you.
Probably just a bunch of local stuff.  Donít want to venture too far with all the new stuff.   Some shake down runs and trips to local shows should hopefully get the rest, if any, bugs out.
There is a monthly show, nothing big, but you can enter multiple categories so I want to see if I can get best 60s car.   Import is too easy.
Also the state fair is coming up and they have a car corral and the mini club goes each year.  Hoping to take it there.  Have also seen some cruise ins happening around.  Hopefully this heat breaks though and we donít carry the non stop 100+ days into Sept.
Online BruceK
« Reply #670 on: August 01, 2022, 09:59:10 PM »
Beautiful!  IMO the Mini looks best on 10 inch wheels with no fender flairs and with the chrome trim instead - just like your car.
« Reply #671 on: August 02, 2022, 09:57:50 AM »
Thanks.  I really like how it turned out with the wheels.  Having some issues though with that trim.  Need to try and smooth out the lip in a few places to get it to lay better.
« Reply #672 on: August 07, 2022, 07:08:48 PM »
So what happens when an engineer is a car guy and an audio nutÖ..
You get a modified heat knob that now controls the bass boost on the amplifier.   Didnít need the heat valve as it is permanently open, that and no heater at the moment and even when one goes in the water can flow through it.   Also needed a place to mount the boost knob so boom. Fixed it.
Online BruceK
« Reply #673 on: August 07, 2022, 09:13:40 PM »
« Reply #674 on: August 19, 2022, 05:43:27 PM »
 :-\     71.gif
