Bruce, watch out for moisture from running that propane heater - they put a lot of water into the air.....tools rust easily when you use those. Running a box fan on low to circulate the air helps.....
OK I'm going to gloat. My garage has the heat in the floor, it was 17 today and 65 inside it makes your feet feel better and I've definitely got the nods while under the car on a creeper....Once up to temp in the fall it costs next to nothing to keep at that temp all winter, the down side is it takes a day or more to raise the temp to 72+ to be able to paint and then the floor is pretty hot.
Wanted to add another heat option I have just discovered. I have a camping trip planned in the mountains next month and having a heat source at night is ideal. I won't have an electric outlet for a space heater and didn't want to bring my 60k btu forced heater that's loud and extreme overkill for sitting in chairs outside at night, or for a quick blast of heat inside a tent. I bought one of these propane top heaters off ebay for 20 bucks or so. 15k btus on the max setting. They sell them in single, dual or triple mount. It arrived yesterday so thought I'd give it a test to see if it's loud and not worth it. Well it's very quiet and puts out a nice blast of heat. I'd think something like this would work very well in a small garage, or direct heat toward your work area. I have a feeling I'll use it in the winter to sit on my patio too.
i got a pair of 220v heaters off of amazon, wired a 30 amp breaker in for each one, or else my garage in the new house will be at 51 deg so far this winter up here in utah
Quote from: joakwin on January 06, 2022, 12:00:20 PMi got a pair of 220v heaters off of amazon, wired a 30 amp breaker in for each one, or else my garage in the new house will be at 51 deg so far this winter up here in utah How big is your garage? I've got a detached double garage, about 500 square feet. The garage is insulated and has an insulated door. I use a single 220v 5000W construction heater. In the Great White North, it's -34 outside right now, but room temperature in the garage.
