Author Topic: 1960 R1 Mini Project  (Read 17359 times)
Re: 1960 R1 Mini Project
« Reply #75 on: October 28, 2016, 12:36:20 PM »
Did you use black filler strips in the windshield seals? I didn't know they offered them in black......
So, next is the engine install?
Offline roadhouse
« Reply #76 on: October 28, 2016, 02:08:28 PM »
Yeah the filler strips are actually made for a 70s chevy pickup I believe. Glass guy at the body shop found something to fit so they could finish up the install. Forgot to order chrome filler strips with the seals. I have since ordered a set and may switch them at some point.
Next is rear suspension install. Waiting on a few parts then I should be able to finish assembly and bolt the subframe up to the car. Then it's front suspension and engine time :)
« Last Edit: October 28, 2016, 02:18:04 PM by roadhouse »
Offline towjoe
« Reply #77 on: October 28, 2016, 07:43:33 PM »
Black filler strips are better.  The chrome ones fade pretty fast.
Regards
Offline John Gervais
  • A Really Swell Guy
  • 1380cc
  • Total likes: 26
    • Copenhagen, Denmark
« Reply #78 on: October 28, 2016, 07:57:20 PM »
Or from MiniSpares:
37H8052
Offline roadhouse
« Reply #79 on: October 30, 2016, 06:02:54 PM »
Welp, the little mini finally made it back home yesterday. Very happy with the color and work performed by Andy's Hotrods and Restoration. Good bunch of guys over there if anyone needs some work performed in Tulsa. After this they are now "experts" on classic minis lol.
I was a little nervous about strapping the finished shell down on the trailer but it ended up being ok. There were some attachment points on the front of the shell and then we went through the doors and around to the back. All while the shell was only resting on its rolling cart. I swear I went about 35 miles an hour all the way home but we made it with no issues!
A few body issues still remain...I need to add the rubber trim to the rear flares, mount the rear license plate lamp holder, adjust hood struts, and figure out the door key issue. You can only open the door with the key in one position but in that position you can't take the key out. Otherwise the door is always locked. Kind of strange...
Anyway, thanks for following along so far. I suppose now the real work can begin.
Sorry- some of these pics are a little dark. whomp
« Reply #80 on: October 30, 2016, 07:13:10 PM »
A shell that looks that good provides a real incentive to go complete quickly!
2007 Triumph Bonneville
