oil filter change mistake
Started by Hayman9644, June 09, 2009, 11:17:33 AM
Hayman9644
   Yep I made a mess.  Thought I would share it with you guys so you dont do the same thing I did.  I changed my canister filter and used the wrong gasket that goes against/inside the part that is on the block and between the can.  I used a wix filter and should of used the middle sized gasket.  Also just FYI  I got a larger o ring for the long bolt.  The one they supply is small and wasnt sealing totally.  So if anyone needs a larger O ring let me know and I can send you one for postage and cost.
Minicop
Haha Ohh ya! I had the same thing happen to me before I changed to the screw on type! Sprinkler! I struck black gold in the garage! I didn't make any money either! :D To hell with that canister!! The stupidest design ever!
Hayman9644
Yes I deffinetly am going to convert mine to the spin on type after this last mess.  One of the guys at work said he could possibly make me one.  Maybe copy yours once you can get some pictures of it.
