Author Topic: Reggie: The '96 Rover Mini  (Read 39997 times)
Offline LilDrunkenSmurf
Re: Reggie: The '96 Rover Mini
« Reply #225 on: October 25, 2017, 08:00:22 AM »
Checked the trap and all the lines, all seems clear. I will be ordering a new SPi air filter, eventually.
This also happened. Check the before numbers.
Mini on the rack by Jory Irving, on Flickr
Alignment by Jory Irving, on Flickr
The front passenger side (or drivers side for RHD), was dialed back on camber as much as possible. I literally can't get less camber, so the other side was made to match. It also took us 30+ minutes with the toe plate on the rear drivers side. I couldn't get any less toe in than that.
Online MiniDave
« Reply #226 on: October 25, 2017, 09:17:45 AM »
Do you have adjustable camber lower control arms, and if so what style? Some are harder to adjust than others, and some don't adjust very far at all. If you don't have them you can install them and set your camber wherever you want it, same with caster - adjustable tie bars.....that way you can dial it in exactly where you want it. I find this style easiest to set and they're well made and heavy duty.
https://usa.minisport.com/spdsp431a-heavy-duty-adjustable-mini-bottom-suspension-arms.html
You need these to adjust the caster - I think 4* is a lot, I run 3* on my cars, but it's in spec.
https://usa.minisport.com/c-8g4249-mini-sport-adjustable-front-suspension-tie-rod-pair.html
How does it drive now, any better? What was it doing before?
To get less toe in the back you need to either put shims behind the bracket or use adjustable brackets. I have a new set of Mini Sport rear camber and toe brackets I can sell you if you want them.....I don't need them. They're normally $75, I'd take $50 (US) plus shipping.
I like to run .5* camber, front and rear, a little toe in in the rear and a little toe out in the front
« Last Edit: October 25, 2017, 09:29:54 AM by MiniDave »
« Reply #227 on: October 25, 2017, 12:39:19 PM »
I have adjustable everything. Camber arms, caster, toe/camber plates in the rear.
Drives way better, but while under the car, I noticed the leaking brake fluid. I just dug into it, and the cylinder is just gushing fluid. One piston is completely stuck, the other is a waterfall, so I just ordered some new 3/4" bore cylinders, an air filter, a spare oil filter, and a replacement vacuum line for the intake.
Online MiniDave
« Reply #228 on: October 25, 2017, 01:14:48 PM »
And some new shoes? If they have brake fluid on them they'll get sticky and drag or lock up.....
« Reply #229 on: October 25, 2017, 01:18:24 PM »
Didn't realize that. Welp. I'll have to look into either getting some replacements, and in the mean time, just ensuring these are really clean. It's unfortunate, they have quite a bit of meat on them. I'm also trying to spend as little right now, as my contract ended, and I haven't managed to line up some more work yet.
Online MiniDave
« Reply #230 on: October 25, 2017, 01:34:25 PM »
Sometimes you can clean them up OK with a can of spray brake cleaner, but not if they've been soaked. New shoes are only about $18/set at Victoria British.....their part #6-510
http://www.victoriabritish.com/icatalog/sm/full.aspx?Page=40
they can't be a whole lot more up there.....
Offline jeff10049
« Reply #231 on: October 25, 2017, 11:53:45 PM »
A new one isn't too bad, 13.29 or about $23 Canadian......
http://www.minispares.com/product/Classic/Engine/NPC10001.aspx?10&ReturnUrl=/search/classic/fuel trap.aspx|Back to search
So Jeff, what does it do exactly? trap fuel in the vacuum lines? And if so, how does fuel get into the vacuum lines?
Keeps moisture/fuel/oil residue out of the map sensor located in the ecm. The trap is known to plug up and cause rich/poor running due to low signal to the map.  The temp sensor could also be a likely culprit.
« Reply #232 on: November 02, 2017, 02:25:50 PM »
Drum Cylinder 1 by Jory Irving, on Flickr
Drum Cylinder 2 by Jory Irving, on Flickr
Filter by Jory Irving, on Flickr
This happened. Once it warms up, I'll do the other side as well, since I ordered 2 regardless. I hate the c-clip, but I figured it out. Reused the old bleed nipple, as it was larger and fit the tubing I was using to bleed the brakes. One of the pistons is completely seized on the old drum cylinder.
Online MiniDave
« Reply #233 on: November 02, 2017, 03:55:18 PM »
Once you get them both sorted it should make it stop better! What causes that is people not changing their brake fluid - EVER!
 ;D
« Reply #234 on: November 05, 2017, 12:50:26 PM »
I bled the brakes when I rebuilt the rear subframe, and installed the braided lines all the way around. I just wanted the leak to stop, so I did the one side, moved it to the driveway, pulled the battery, put the car cover on it, and it's now under ~20cm of snow. Went through half a can of brake cleaner, cleaning up the shoes, backing plate and such.
Come spring (or a chinook to melt all the snow), I'll do the other side as well.
« Reply #235 on: April 06, 2018, 11:32:00 AM »
Well spring made a short appearance, so I did the other brake cylinder, and adjusted both rear drums using the video from Stevensonmotorco, which was very helpful and informative.
But now that I drove it again, I remember it shimmy's at 80kph+. It's frustrating. I'm going to try the typical things like swapping wheels around, but it's got all new suspension, new LCA, new balljoints, new everything except front subframe bushings.
I know it's a project car, I know what I signed on for, but cant I get like... one solid drive in? That's not too much, right?
Online MiniDave
« Reply #236 on: April 06, 2018, 12:29:00 PM »
My green Mini does the same thing, it's very frustrating. I have all new suspension, bearings, discs and pads, the alignment is right, I've tried moving the wheels around, I've had the wheels on the balancer a bunch of times and checked them for true and out of round and they're good, I've tried different wheels from another car. It's still there.....annoying as hell!
« Reply #237 on: April 06, 2018, 12:47:36 PM »
I'm worried it's going to be something else I haven't tried yet, like the driveshafts. I haven't had much success pulling them out of the transmission case, but I didn't try that hard, for fear of finding something else I need to replace hahaha.
Online MiniDave
« Reply #238 on: April 06, 2018, 01:18:50 PM »
The only way to get them out is to release one of the ball joints so you can move the hub outward, then I prefer to cut the clamp on the boot and slide the inner pot joint apart, rather than popping the joint out of the transmission.
I'm also wondering about the axles as that's the only part of the front end I haven't rebuilt. I'll be pulling mine next weekend, I'll let you know what I find, if anything.
« Reply #239 on: June 06, 2018, 01:02:55 PM »
So I broke the rear bumper bolts removing it (they were rusted and snapped the studs) to replace the hinges for the boot/trunk. So that's great, guess I'll need to order a new one?
Additionally, I crawled under the engine to see if the gearbox shifter was leaking, and it doesn't look like that is the culprit. Someone above the passenger (usdm driver) driveshaft is leaking oil onto it, which is then spinning it bloody everywhere. It's a goddamn mess, and I have no idea how to tackle it, without removing the engine. Additionally, I still can't figure out how to remove the dash, so I can make some gap fillers for the deleted a/c vents.
Some days I love this car, some days I hate it. Today I'm not sure which it is.
Online MiniDave
« Reply #240 on: June 06, 2018, 01:33:00 PM »
On the left side of the engine there are only a few places oil can leak from, the valve cover gasket would be a prime candidate but you replaced that already. About the only other thing there is the crankshaft seal or the timing cover itself - there really isn't anything else over there that can leak oil.
The main oil pressure side is the front of the engine, that's where the main pressure pipe to the filter is, the oil pressure sending unit and the pressure relief valve.
« Reply #241 on: June 06, 2018, 02:44:28 PM »
Knowing my luck, it is the crankshaft seal or the timing cover. It could be the actual gearbox leaking where the driveshaft mates, but I still don't know how to remove it. I wish I had a resource that didn't cost $140/hr in labour, locally.
« Reply #242 on: June 08, 2018, 04:20:53 PM »
flipstah came by to steal an oil filter, and listen to my "buzzing/rattling" sound. We're pretty sure it's exhaust. I think it's either the slip joint on the manifold, the heat shield, or a washer somewhere in the engine bay. So weird.
Offline flipstah
« Reply #243 on: June 08, 2018, 05:10:28 PM »
When you step on the throttle, it rattles like a washer vibrating on something. It rattles faster as the revs go up.
Online MiniDave
« Reply #244 on: June 08, 2018, 05:29:42 PM »
Does this car have a cat? Cause that's usually what causes this type of noise, a broken weld or tab on a heat shield around the cat.....
« Reply #245 on: June 08, 2018, 10:54:19 PM »
It does, but when I replaced it with a straight pipe, it continued. It's 100% coming from bottom of the engine bay.
Offline gr8kornholio
« Reply #246 on: June 09, 2018, 10:49:06 AM »
Glad I read this again this morning, cause last night I was like, why would the car have a cat(meow) and if one was stuck in a car when it started it usually shreaks, not rattle.
Offline Shrimps
« Reply #247 on: June 12, 2018, 01:20:02 PM »
On the water pump end of the block, and behind the coolant bypass hose (if equipped) between the block and head is the oil passage that feeds the rocker arms on the head.  If the head gasket is leaking at that oil passage it can make quite a mess.
I had a 998 leaking there that I didn't notice at idle, but once I brought the revs up I could see oil running out between the block and head behind where the coolant bypass hose is.  I went from a nice cleaned up block (after fixing a couple other leaks) when engine was out, to having oil dripping on the ground after a quick few minute low speed drive down the block and back.  I installed a new head gasket which resolved the leak.
