Author Topic: Then I broke down (74 mini mild refurb)  (Read 88123 times)
Re: Then I broke down (74 mini mild refurb)
« Reply #650 on: October 26, 2020, 07:23:43 PM »
How are you going to run the oil drainback line from the turbo to the sump?
Online 94touring
« Reply #651 on: October 26, 2020, 10:39:28 PM »
The turbo sits over the breather and it looks like everyone just feeds into that.
« Reply #652 on: November 02, 2020, 04:55:14 PM »
Since we're talking about boost, we should probably talk about lag too.....
Online 94touring
« Reply #653 on: November 02, 2020, 05:38:30 PM »
I picked a smallish turbo to minimize lag.  In fact this gt1549 turbo has a few different wheel trims that are more suitable for small bore engines. I took that same platform and went with the biggest wheels available for that size turbo that are better paired for a large bore.  You don't want a turbo capable of 250hp when you are shooting for 120hp.  Another thing I'll be doing is injecting my water/meth combo directly into the turbo compressor.  This effectively changes the turbo map creating a more efficient output due to the reduction in compressed heat.  You can run a smaller turbo but more boost this way that would normally stop producing power at the same boost levels.  As well as it eliminates detonation should you accidentally run lean.
Offline Willie_B
  • CREW
  • 1275cc
  • Total likes: 89
    • Lilburn, GA,
« Reply #654 on: November 09, 2020, 08:23:09 PM »
Just stumbled onto this site. They have some cool stuff like how to convert a A engine to 5 groove serpentine belt. They also some nice bits for supercharging or turbo. Plate for raising thermostat housing so can use a GM temp sender in the gap. The easiest way to see what they have is click on the Purchase tab. Pic shows temp sender and serp. belt.
https://www.creativespridgets.com/
« Last Edit: November 09, 2020, 08:31:17 PM by Willie_B »
Online 94touring
« Reply #655 on: November 18, 2020, 11:10:51 AM »
Putting the mini to work today.  Have this 998 auto I needed pulled into the shop to haul up to Dave.
Someone was asking about auto shift cables...
« Last Edit: November 18, 2020, 11:13:45 AM by 94touring »
« Reply #656 on: November 18, 2020, 12:09:04 PM »
If that's going in the Pup, won't he need the subframe too? In fact, he'll need a two bolt automatic subby, right?
Are you going to build the subframe up for him? Disc brakes and such?
« Last Edit: November 18, 2020, 12:11:10 PM by MiniDave »
Offline cstudep
« Reply #657 on: November 18, 2020, 12:30:15 PM »
That auto shifter looks the same as the one I dug out of a box o' junk maybe I will hold onto it in case someone needs one some day. Thanks for the pic.
Online 94touring
« Reply #658 on: November 18, 2020, 01:42:20 PM »
Yeah I'm building subframes for him.  But this auto subframe is a 1 bolt so I have to fabricate a little on the pickup bulkhead to support it.
Online 94touring
« Reply #659 on: November 19, 2020, 07:35:22 PM »
Gave the car a wash today and got the new 59D timing locked and setup with the black box and verified with timing gun.  Took it for a spirited drive.  After driving the bus for the past week the mini felt like a formula car.
Offline G67mcs
« Reply #660 on: November 19, 2020, 08:50:09 PM »
I see your Mini makes a good tow vehicle as well  ;D
1967 MK2 S
2003 Mini Cooper S
2016 4Runner
