#550
Back in the day when tuning an SU by the seat of your pants on a Mini or any SU for that matter to save buying endless needles we used to move the needle up inside the piston to make it run richer through the range or out to weaken it.
Also the collar can be removed on the non fixed needles so they can be used as a fixed needle and vice versa.
I will move the needle up and down as well.  Saves me having to remove my huge filter box assemble to make small adjustments.
Making a few alterations. Haven't been incredibly happy with the fiberglass bonnet so acquired a steel skin.  The other thing on the other bonnet is the leather straps basically suck, so have some steel clips and some other hood buttons to secure it all down so it's not flopping around.   Also have a hif44 on the way to do some testing with.
Hoping to have some things painted next week.
Test fitment.  No more sloppy rattling bonnet.
MiniGene
Getting the studs for the push buttons lined up perfectly is imperative.  Otherwise they put to much pressure across the bonnet and it binds up when you go to unbutton them.  To help aid in releasing the bonnet I added springs that sit over the studs so when you push the buttons the bonnet comes up and is easy to grab and sit to the side.  I added a rubber trim piece to the edges of the bonnet and can just sit it on the roof.
No more warped and wobbly looking bonnet.
Got the rest of the hardware on so I can actually drive it again.
So, how dies it run with the single carb?
I've yet to really drive it.  Maybe tomorrow if I have time.
Vikram
Where are those push buttons and latches from Dan? Looks really good!
Push buttons are from ebay and spares sells the latches.
#565
Because 100hp is just not enough!  ;D
Good place to take the oil drain line is to tap the flat plate where the fuel pump used to go, then put a fitting in it - drains right into the sump. Or into the breather base on the drop gears housing...
When did you get the DSN engine steady?
Oh I've had the engine steady since building the car.
I know it has the Dsn rear arms, they now have front upper arms.
The rear radius arms are KAD along with their disc brake conversion.
Lone Star Mini
While y'all discuss hi-tech stuff, I'm just loving the color and the bonnet with those air vents...
Lone Star Mini
1992(?) Mini Cooper
1964 Austin Cooper
1980 Mini 95 (Pickup)
So, what are you going to build the intake and exhaust manifolds out of? Start with a regular header and build from there or just go all in and start from scratch?
You'll want a laser or water jet cut flange plate for the head end, and I was thinking rather than having two separate manifolds, just weld it all up as one thing to bolt onto the head? An intake gasket would work fine for the template for the flange plate....just need to find a local shop that can cut it out for you.
Intake manifold will just be the standard hif44 hi flow style I currently have on there.  Exhaust manifold I have one to chop up, so I can use the flanges and it will be one piece manifold.  I have looked at several custom made and the one that jetmotors has.  Jetmotors I'd just buy and slap on except the one runner basically flows backwards...dumb.  I could buy it and modify it, but if I'm going to do that I'll make my own. Then I need to do a downpipe.
#573
Some examples.  Mine will be cleaner like the jetmotors.
#574
Those pics illustrate my point exactly - why not make an intake manifold in the same tubular weld up? Especially if you're using FI it should be easy to do and a simpler final package. I understand it you're just going to use the std HIF44 might as well use the manifold too....
Those all look like they're going to use the SU in the original position and simply blow thru the carb mouth? I thought you had to pressurize the entire carb, but I guess not with the HIF44 design with the internal float chamber?
In the Jet Motors pic, can't you rotate the outlet side of the intake on the turbo to point pretty much anywhere? If so, I would eliminate the U-bend and make a simple 90 to the tube coming off the turbo going to the carb.
