Do the 11275's come with steel liners from the factory?
Started by Merlin, December 25, 2014, 08:30:59 PM
Merlin
When I got this car, I was told that it was bored out to a 1310cc. When I pulled the head off during engine disassemble, I was trying to determine why I had so much oil blowby in the exhaust and checked the cyl dia. I found the cylinder to be perfect for a 1275cc and not a bored cylinder. Once fully disassembled I could see that there were steel liners in the cylinders. Do the A-series come with steel liners or were these put in afterwards? If these were put in because of over boring, can they be bored out?
Engineering the Impossible
Some came with liners I think it had something to do with porous casting of the block.
Yes they can be bored how much depends on the liner thickness. A 3/32" or 2.49 mm should be good for .030-.040 over. you can always bore it out completely and install a thicker liner if it has 1/16" liners now.
Jeff
Edit LA Sleeve will have what you need if you end up in a re sleeve. http://www.lasleeve.com/all-purpose-sleeves
