Author Topic: Radius arm bushing Reaming.  (Read 1752 times)
Offline AcesLow
« on: October 12, 2014, 07:24:44 AM »
Can anyone tell me a part number for the proper type of reamer I need? I know it needs to be 13/16 and the needle bearing has to be installed to support the reamer to do the job.  Taking a break from body work and getting the sub frames built up.
Offline MtyMous
Re: Radius arm bushing Reaming.
« Reply #1 on: October 13, 2014, 12:37:07 AM »
Aces,
I borrowed one from a friend, but it looked almost identical to this one.
He had drilled a hole in the end and tapped it to accept a bolt so it could be easily turned. Then he used some thick tape to match the inner diameter of the bearing to be used as a guide.
« Last Edit: October 13, 2014, 11:59:36 AM by MtyMous »
Offline AcesLow
« Reply #2 on: October 13, 2014, 04:27:42 AM »
Offline MtyMous
« Reply #3 on: October 13, 2014, 12:05:59 PM »
Sorry. The link in my first comment was all jacked up. Click the link and it should work now. Looks very similar to the one sold by fastenal. I deal a LOT with Fastenal and they are quality, but definitely one of the most expensive options out there. I've not used the sit eI linked to. It's just the lowest price I could find on the right specs.
Offline AcesLow
« Reply #4 on: October 13, 2014, 11:10:29 PM »
Straight flute 13/16 reamer and its long enough.. I'm going to order it and try it
Offline MtyMous
« Reply #5 on: October 14, 2014, 12:46:31 PM »
Aces. I sent you a PM last night. Check it before you buy.
Offline Mudhen
« Reply #6 on: October 29, 2014, 04:59:20 AM »
Let us know how you make out...I was thinking this was a machine shop only thing but all you guys doing it on your own I might give it a go...
Offline AcesLow
« Reply #7 on: November 07, 2014, 04:53:42 PM »
Will do.  I'm doing it tonight.
