Author Topic: 1960 Austin 850 Project  (Read 39955 times)
Re: 1960 Austin 850 Project
« Reply #250 on: January 12, 2020, 11:15:43 AM »
Yeah, the only time I've seen a float cause trouble is when it fills with gas and sinks, flooding the engine. You can tell by holding it near your ear and shaking it - you'll hear the liquid if it's in there.
I wonder if it's just the needle - the ones with the rubber tips sometimes react to ethanol fuel and swell up - sticking closed usually.
2004 Audi Allroad 2.7 TT
Offline tmsmini
« Reply #251 on: January 12, 2020, 12:17:54 PM »
I think you meant Joe Curto, he has been very helpful.
http://joecurto.com/
Offline tsumini
« Reply #252 on: January 12, 2020, 02:01:53 PM »
That is the wrong float for your float lid.
Get in touch with Joe Virgo in New York he has the right part and is very knowledgeable regarding SU's.
I am not sure the float is the problem though.
Have you tried running the car with the float lid removed and just topping the float bowl off to see how long it runs?
Just ran without float; have to coax it to start full choke pump accel pedal. Dies when it goes down to idle.
Looks like resetting the carb.
Yeah float looks wrong.
« Last Edit: January 12, 2020, 07:49:21 PM by tsumini »
Offline tsumini
« Reply #253 on: January 12, 2020, 02:05:00 PM »
looks like i need to re-set carb. Check timing etc. Start all over again. Fuel supply ok.
Offline Jimini II
« Reply #254 on: January 12, 2020, 02:22:18 PM »
Yes I did mean Joe Curto stupid spell check on this tablet.
I would remove the jet and see if it is kinked or the o ring is damaged or distorted due to ethanol.
Offline BruceK
« Reply #255 on: January 12, 2020, 06:18:43 PM »
Oh thatís a thing?  I hadnít heard that.  I will need to check my carb.
2007 Triumph Bonneville
Offline tsumini
« Reply #256 on: January 12, 2020, 08:19:15 PM »
Just watched his video on covers. Confirmed I got the wrong float. Again I think the float i have is OK . The carb itself is the problem.
Offline Jimini II
« Reply #257 on: January 12, 2020, 09:38:24 PM »
The SU is simple in design of you have fuel pressure only the jet, bottom of the float bowl or the needle and seat can stop the flow.
When you replaced the jet did you get the old o ring out as they usually get stuck in the float bowl.
Also did you center the jet? Sometimes it is not necessary if it is centered correctly you can lift the piston and when it drops it should hit the bridge with a nice clunk sound.
Sorry if some of this is repeated.
Offline tsumini
« Reply #258 on: January 12, 2020, 11:27:30 PM »
Thought I had mentioned it before but see that I haven't. I suspected the jet tube may be off so I removed the dashpot housing and cleaned it with carb cleanre. It dropped into the jet tube and showed no signs of being off center. I also blew air back into the bowl and showed the jet tube to be clear. I had rerplaced the jet tube earlier due to a leak at the bowl connector(bad gasket).
I cvould get it started but had to pump the accelerator furiously to get it to run. Then it would sputter a while die when it went back to idle.
Offline tsumini
« Reply #259 on: January 19, 2020, 11:49:55 PM »
Well after several days of checking this and that I decided to take the carb off and see if there was anything wrong. Couldn't reealy find anything that would affect fuel delivery. I found the choke return spring mis-installed. It didn't return the choke lever all the way back.
Jet tube was free to move. Piston was free. I expected maybe to see the throttle shaft worn but .010 total play in the shaft didn't seem enough to affect operation. I ran it later and moved the shaft  back and forth with no change in operation.
Re-installed the carb and didn't see any improvement. I did note that the SU FP stopped running when it was stalling. I thought it should keep running   since the engin exhibited fuel starvation symptoms. So I hooked up the new electric Fuel pump drawing from a tank sitting on the floor. The car ran muck better and started  cold much better.
 I decided to install the new FP. While removing it I found that one hose was bent 90 degrees without aaan elbow effectively interfering with the flow. By this time I was committed to the new FP rather than correct the old FP installation. Comleted the install and took a spin. It started cold fine with little choke. It runs well even cold and better at operating temp although i noticed a couple of stumbles where the high idle stumble briefly back to sub idle.
https://youtu.be/2JMvkaTKNRQ
Offline tsumini
« Reply #260 on: January 19, 2020, 11:55:32 PM »
A few photos of the project.
« Reply #261 on: January 20, 2020, 10:35:24 AM »
Wow! This car is fantastic!
Look how far you've come with it, for a while there I wasn't sure you'd finish it, but I bet you're glad now that you stuck with it.
Now to get some miles on it so you can join us in San Antonio for our Texas run in late April.
Offline Jimini II
« Reply #262 on: January 20, 2020, 11:14:13 AM »
Looks great.
Since you did a gravity test and the results were similar I would not have guessed a fuel pump or kinked line, glad you have it somewhat sorted.
If you have not already done so remember to set and check everything else before setting the carb up, points, spark plugs, vacuum advance, distributor advance weights and springs, valve clearances, timing, maximum timing advance, then set the carburetor.
Also regarding the bumpers can you tell me the length of the longer early ones as I may have access to a decent early one on an early 62 Mini, not sure if they went to the later shorter ones by then.
Offline BruceK
« Reply #263 on: January 20, 2020, 05:47:21 PM »
Nice car!  I love the very early seat cover material - I've seen an ancient Mini seat beat the hell with that unusual material (a seat with the little 'feet' at the back rather than the bent tubing).  But your seats look fantastic.
Offline tsumini
« Reply #264 on: January 20, 2020, 08:24:50 PM »
Thanks for the kind words. It was a struggle staying motivated but got down to it the last couple months. It will certtainly be the last. The old bones wont take much more especially crawling under the car to change a FP. At least my last house had a lift. I'll work on April. Hope I can get the stumble out by then.
Offline tsumini
« Reply #265 on: January 20, 2020, 08:45:04 PM »
Thanks for the kind words. It is much appreciated.
The seat material is a reproducction of the original material and sold by 1959 Register. It was original to this car (Basic Model) so opted for this. Overall the upholster did a good job on the seats but was a little disappointed in the back Seat back. He didn't make it wide enough and I had bought the original cover to him but couldn't bring the car. But it turned out OK I made the door cards and fillets and rear panel cards.
i look at it now and think the pattern is rather overwhelming  and should have been  moditied. I think it would look great as an insert such as jeff10049 did on his 60 interior. In fact I may have some extra pieces that could work but don't know if there's enough.
Offline tsumini
« Reply #266 on: January 20, 2020, 09:21:33 PM »
Looks great.
Thanks, I think the car is running much better although It stumbles at idle for no apparent reason almost like a momentary glitch is fuel. I may crawl into my trailer and retreive a carb from the 60 Morris and see if that helps.
The long bumpers were designated "long' because they extended back a little. It would be difficult to measure the length. I think they were only about an inch longer and was difficult to identify.  The 59 Registry shows the difference. It also says that they were installed only until April 1960 so this January 60 has the orignal bumpers.I verified long with Bill Bell back in 2016. I have parts of a July 1960 Morris and it had the third bumper in the photo and is a "short" bumper and also with five mount holes. Notice that the bolt holes are square holes as opposed to the slots in the long bumper. The lip with the holes is slightly wider also.
I've also attached a photo of three together.  I exchanged emails and photos with a guy from Canada that had an NOS long bumper that we compared to mine. Regarding your lead on a bumper; a picture of the end should tell if it's long or short.
Thanks again for your help.
Offline jeff10049
« Reply #267 on: January 21, 2020, 11:23:56 PM »
Nice  4.gif. My back seat came out a little too wide I guess they really need the car to get it perfect.
