1964 Morris cooper s 1071 project
Started by scottb6058, April 28, 2009, 07:21:12 PM
scottb6058
http://minimorriscoopers.blogspot.com/
I got myself into this mess but should be worth it.
A tall order to fill but I can do it.
I need help with the drive train and engine 90% of the parts are here.
Wish me luck.
Best regards Scott
My idea with this big project is to take it back in time with the patina it deserves, some pitted chrome, all original brocade maybe a scuff or stain but all there.
MEhinger
That is quite a project you are taking on. I am eager to see your progress.
scottb6058
Thanks MEhinger
Yes it is a bit scary.
I should be able to show some progress as soon as my M-Machine panels arrive.
Just waiting for the half floors. Money has been tight but it is mostly labor at this point.
Thanks for the interest and reply.
Best regards scott
That does look like a big project, so I can't wait to see what you do after your panels come in.  Keep us updated for sure.
scottb6058
#4
Thanks for every ones thoughts and comments.
I acquired the mini in the mid 80's and with out any history for $600.
I really didn't know that was a 1964 Morris 1071 cooper S never re-shelled.
Lucky enough it is a small simply car but it is complicated restoration.
I'll keep the pics rolling if you wish.
Best regards Scott
HelenJames
I have send you in pm
scottb6058
Sorry Buddy
I don't see a PM.
Thanks Scott
scottb6058
I'm finally getting my 190 gearbox sorted.
I sourced a perfect set of S gears from another box but still needed to buy these bits.
1 CHM172 first motion pilot bearing
1 AAU 8424 outer support first motion bearing w/ race
1 AAU 1365 double ball bearing third motion shaft
3 22 G 2033 Rover synchro rings
2 GUG 705567 GM side cover gaskets
2 88 G 302 3 synch idler bearings
1 22 A 610 3/4 shift fork
1 22 A 611 1/2 shift fork
1 2 A 3709 roller three synch first motion bearing
1 22 G 189 gear lever bush remote
1 AAU 2304 speedo drive seal
1 13 H 577 shift rod seal
2 DAM 5071 spider thrust
2 88 G 396 lay shaft bearings
6 2 A 3647 shift hub detent springs
2 22 A 1566 HS bolt seals
2 2 A 3502 diff shift rod bushes
1 DAM 4000 loc tab
2 AHU 1856 diff side ball bearings
1 C-BTA 166 diff pin
1 GUG 708014 TS tranny gasket set
2 DAM 2377 loc tabs 3 rd motion bearing
1 DAM 6140 pinion loc tab
3 ATA 7385 crown wheel poc tabs
2 BTA 101 diff side thrusts
2 DAM 6624 diff spider gears
2 22 G 421 HS side bushes
2 AHU 1082 HS side seals
$900 US dollars and I'm broke again :oops:
Scott
HEY, you are still working on it!   ;D
scottb6058
Hi Dan
I'm still in the planning stage. I'm trying to get my ducks in a row at the moment. Everytime I think I'm ready my son pulls another project out of some corner 11.gif.
Current project is a 1975 BMW 2002 I had stashed years ago. Here is a picture of the engine to be installed. If all goes well I'll be able to post some progress pics of the 1071 soon.
Scott
