Author Topic: 1978 Pickup, giving her some love...  (Read 116784 times)
Offline Jims5543
  • 1380cc
  • Total likes: 291
    • Jensen Beach, FloRida
    • My Land Surveying Website
Re: 1978 Pickup, giving her some love...
« Reply #525 on: September 04, 2016, 05:51:01 PM »
Yup have all the balls.. it is remarkable how much variation there is with these cars.
Got the brake line in, starting to think I should have done this with the engine out.
« Reply #526 on: September 04, 2016, 06:52:06 PM »
Lol that last pic made me laugh.  My last brake line connector you're flipping off gave me so much grief.
Offline Jims5543
  • 1380cc
  • Total likes: 291
« Reply #527 on: September 04, 2016, 08:34:30 PM »
Seems the coil over kit is a bit more involved than initially thought. Just dug into it and was a tad bit surprised but releived at the same time. More when I am on an actual keyboard.
« Reply #528 on: September 04, 2016, 09:21:38 PM »
I'll be interested to hear what you think of these as I was going to order some too.....did you get standard height or lowered?
Offline jeff10049
« Reply #529 on: September 05, 2016, 05:08:02 PM »
 I like to use something like the red bearing grease to hold the balls in place as the cv grease is often to thin then fill the rest of the boot with the proper cv grease. That pot part of the joint also comes out of the transmission if you want to assemble it on the bench and then put it in. It has one of those spring clips on it.
Offline Jims5543
  • 1380cc
  • Total likes: 291
« Reply #530 on: September 05, 2016, 07:29:33 PM »
Fukitall...
It may be weeks before I approach this truck again.
What was supposed to be a simple exchange has turned into a big deal.
2 bolts on the drivers side (RHD) have snapped. Fuckit I need a break.
« Last Edit: September 05, 2016, 07:34:26 PM by Jims5543 »
« Reply #531 on: September 05, 2016, 08:13:50 PM »
Ship it to me lol
« Reply #532 on: September 05, 2016, 09:19:29 PM »
Or buy me a plane ticket and I'll come down and fix it.....
Offline Jims5543
  • 1380cc
  • Total likes: 291
« Reply #533 on: September 06, 2016, 06:16:05 PM »
Both of you calm down and get you mitts off it.  ;D
I will get this sorted out, just hoped to make more headway over the 3 day weekend and I feel like all I did was make more of a mess.
I have some ideas how to make this work.   I was going to have to drill some holes anyway as the new brackets require 6 holes with 2 new ones above the  4 on there. I am just going to drill them out and use some beefier bolts to hold it in there with a backing plate on the other side. I hope otherwise some large washers at the very least where I can fit them.
« Reply #534 on: September 06, 2016, 07:55:58 PM »
To make Jim feel better I sent a pic of a car I'm working on.
« Reply #535 on: September 06, 2016, 08:26:17 PM »
Is that the other local car?
Not Rusty the Clubby then......
« Reply #536 on: September 06, 2016, 08:39:57 PM »
Okc mini that Patton has.
« Reply #537 on: September 06, 2016, 09:33:18 PM »
I thought it might be....even worse than the other one?
« Reply #538 on: September 06, 2016, 09:46:51 PM »
Yeah requires a whole front end among many other things.
Offline Jims5543
  • 1380cc
  • Total likes: 291
« Reply #539 on: September 09, 2016, 06:41:38 AM »
I am sitting here debating pulling the engine back out getting the brakes and suspension done then dropping it back in. I am pretty sure I could have it out in an hour or less now.
Then I would have room to work on the things I should have done while it was out. I had no idea these items would be so hard to reach with the engine in.
« Reply #540 on: September 09, 2016, 06:46:30 AM »
In the long run that probably is going to be easier.  Pulling and dropping in motors is pretty painless.
Offline jedduh01
« Reply #541 on: September 12, 2016, 10:57:33 AM »
Dropping Subframe with Engine inside would be the best of both. Less engine stuff to take apart= but All the suspension access for replacement and repair.
« Reply #542 on: September 12, 2016, 12:17:33 PM »
I agree with Jedduh, drop them both, then you can get at everything you need to do easily, and going back in is a doddle.....plus if you want it's a perfect time to have the subframe powder coated or painted.
This winter I'll be pulling the engine on the green Mini to change the final drive and one thing I will definitely do is wrap the header, it takes all of the exhaust system heat out of the engine compartment, no more burning your arms or fingers when reaching in back of the engine for something, and no more hot bulkhead and floors. I bought a kit off Ebay for like $25, it has enough to do 2 cars or to wrap all the way back to the front muffler if you want..
« Last Edit: September 12, 2016, 12:21:19 PM by MiniDave »
Offline Jims5543
  • 1380cc
  • Total likes: 291
« Reply #543 on: October 30, 2016, 08:04:09 PM »
Finally diving back into this thing over the last couple of weeks. I have the front brake lines finished. I did not have to pull the engine either, once I realized the solution I laughed at myself.
2 quick questions:
1. the CV shafts, I am trying to slide the outer hub on and cannot get it to go over the keeper c ring. Is there a trick to this? Or a tool I need?
2. The inner joint, what style is this and can I order a replacement? I ordered what I thought were the correct inner joints and they are wrong.
This is what the old and correct one looks like.
I am slowly getting the coil overs in, after some fab work I should have them in this week then if I can get these shafts done the front of the car is done, then on to the real coil overs.  Pushing hard to get her finished up.
Offline Jims5543
  • 1380cc
  • Total likes: 291
« Reply #544 on: October 30, 2016, 08:08:58 PM »
The brake line solution.
« Reply #545 on: October 30, 2016, 08:22:06 PM »
If the entire axle shaft is out of the car, I start the outer joint onto the shaft, then turn it over and give it a good pop on the floor (on a board of course) usually they pop right on that way......
« Reply #546 on: October 30, 2016, 09:55:09 PM »
The joint in question is the inner half of a "pot joint".  The outer half is likely still on the output shaft of the differential.
Here is what a complete one looks like: (link
The small shaft goes into the differential and the drive shaft inserts into the boot end.
The inner part in your picture pops off much like the outer CV.
Offline Jims5543
  • 1380cc
  • Total likes: 291
« Reply #547 on: January 21, 2018, 09:50:36 AM »
If anyone crosses paths with this Skip fellow that is a renowned Mini guy, and owned this Pickup for years before I purchased it off Playle,  punch him in the nose for me and tell him I said that he should not be allowed near Mini's and should be relegated to owning Toyota Avalons.
Thank you.
« Reply #548 on: January 21, 2018, 10:22:21 AM »
Jim,
I've wanted to do that for you for a long time now.  Skip seems to have dropped out of the Mini community.  I've heard he sold off the other Minis he owned as well.
Offline Jims5543
  • 1380cc
  • Total likes: 291
« Reply #549 on: January 22, 2018, 06:51:49 AM »
I pity any person that purchased a car he has touched.
Hope to have her back on the street by the end of the month.  She is finally back on 4 wheels. I need to adjust the front right coil over it is 1/2" too high vs. the left.  I need to get a punch out list together lots of little things now need to be done all the major crap is done.
