Author Topic: 1978 Pickup, giving her some love...  (Read 166026 times)
Re: 1978 Pickup, giving her some love...
« Reply #25 on: March 03, 2014, 08:26:28 PM »
Ha, missing a nut buddy!
Offline Jims5543
  • 1380cc
  • Total likes: 363
    • Jensen Beach, FloRida
    • My Land Surveying Website
« Reply #26 on: March 03, 2014, 09:34:29 PM »
I thought there was a knocking from day one, it kept getting louder so I was assuming it was grenade time for the engine.
So glad I decided to pull the valve cover and adjust the valves today.
I was shocked to see that, I hope there is no permanent damage to that cylinder.  I am really hoping it is much peppier now.
« Reply #27 on: March 03, 2014, 09:53:23 PM »
Ha yeah you just gained a cylinder.   Explains the knocking.  Wonder where the nut went.   8.gif
Offline Jims5543
  • 1380cc
  • Total likes: 363
« Reply #28 on: March 03, 2014, 11:31:16 PM »
I thought I was going to have to match one up at the hardware store, then I noticed it sitting on the head, you can see it in this picture. My guess is that it was not tightened after the last valve adjustment.
Offline Willie_B
  • CREW
  • 1275cc
  • Total likes: 66
    • Lilburn, GA,
« Reply #29 on: March 04, 2014, 06:35:08 AM »
Hope all this new found power doesn't go to your head.  :-[
« Reply #30 on: March 04, 2014, 10:31:17 AM »
Ah, yeah easier to see from my computer now.  I'm excited to hear back with the results of how well it's going to run.  All those other goodies you got, it's practically a new truck.
Offline Jims5543
  • 1380cc
  • Total likes: 363
« Reply #31 on: March 04, 2014, 05:24:43 PM »
I have a completely different truck now. I fired her up and was initially just going to run her up to the corner store.. I kept going, ended up going on a 20-30 minute drive through town looping around.
The acceleration is now what I was expecting, it runs much smoother and has tons more power.
I am going to pop off the valve cover again and make sure everything is staying put.  ;)
I also need to learn how to adjust the idle, with it running better now, it is idling at 2400 rpms I looked around and did not see an obvious adjustment so I am off to the shop manuals now.
There is a loud knock coming from the engine now that the valves are quiet. Does not sound good, I hope to have a video of that in a few.
« Reply #32 on: March 04, 2014, 05:35:11 PM »
Different than the previous knock huh?  You should see an idle adjust screw off the throttle body assembly.
Offline Jims5543
  • 1380cc
  • Total likes: 363
« Reply #33 on: March 04, 2014, 05:47:38 PM »
Found the idle adjust.
The knock is the same you can just hear it all the time now and it is worrying.
Here is the shorter vid where I rev the engine a little and it quiets down.
Offline Willie_B
  • CREW
  • 1275cc
  • Total likes: 66
    • Lilburn, GA,
« Reply #34 on: March 04, 2014, 06:38:17 PM »
That does not sound good at all. Does it go away when you rev it up or you just cannot hear it then? I chased a clatter/tapping noise for a good while till I found a cracked alt bracket. It would make noise at idle when the cracked parts rubbed each other but when revs went up the parts were pulled apart at the crack thus no noise. Can you slack the fan belt and run it to at least eliminate the alt, water pump and a/c comp?
Offline Willie_B
  • CREW
  • 1275cc
  • Total likes: 66
    • Lilburn, GA,
« Reply #35 on: March 04, 2014, 08:28:42 PM »
Another thing you can do is get a long (2') screwdriver or socket ext. and rest one end on the bone just in front of your ear and the other end on parts of the engine. The sound will transmit thru the meal to the bone and you would be surprised what you can hear this way. Move around and chase the sound as it gets louder. Just beware of moving parts.
Offline Jims5543
  • 1380cc
  • Total likes: 363
« Reply #36 on: March 04, 2014, 08:34:37 PM »
Yes it goes away.. sort of, I am going to check the Valve clearance again.  I suspect the lock nuts are loosening up. I will try some lock tight on there after I make sure I tightened them all correctly.
I swear that constant knock was not there when I initially started it and was there after a 30 minute drive.
« Reply #37 on: March 04, 2014, 08:40:28 PM »
Is there enough space to double nut it?
Offline Jims5543
  • 1380cc
  • Total likes: 363
« Reply #38 on: March 04, 2014, 08:48:55 PM »
 :D
I consider double nutting them yes.....
But, looking at the pics there is no room.
« Reply #39 on: March 04, 2014, 08:54:03 PM »
I just busted out laughing.  A bunch of guys in the crew room gave me a funny look.
Offline Jims5543
  • 1380cc
  • Total likes: 363
« Reply #40 on: March 04, 2014, 08:59:19 PM »
I think the "pc term" here is locknut.
Nice job there Mr. Busta Nut.
Offline MtyMous
« Reply #41 on: March 04, 2014, 09:54:43 PM »
Bahahaha. Double nut. Gonna have to use that one.
Offline Jims5543
  • 1380cc
  • Total likes: 363
« Reply #42 on: March 05, 2014, 06:03:29 AM »
Thinking about this more I do not recall the constant knock when I first started it before the 30 minute drive.
I suspect a valve is out of adjustment again.
I am going to try to find time to adjust them again tonight.
« Reply #43 on: March 05, 2014, 07:36:20 AM »
That would be something if that one won't stay tight.  Seems like there would have been tons of racket if you had two things knocking like crazy.  I'm going to have to make a pit stop down sooner or later.
Offline Jims5543
  • 1380cc
  • Total likes: 363
« Reply #44 on: March 05, 2014, 06:36:15 PM »
Just finished checking the valve train and everything was fine in there. I think the knocking is a con rod bearing. 2400 RPM's is where it likes the knock the most.
Hope she lasts until July, if not, oh well. That is what I get for buying it sight unseen.  edit - not a fair assumption ---  to the seller I apologize. - jim
edit
Just adjusted the idle and have another question.
I know the cable and butterfly closer to the engine is the throttle. I am assuming the one closer to the firwall is the choke?  It is attached to a knob on the dashboard that I assumed was a HVAC control but now see is a hand choke.... I think.
« Last Edit: March 05, 2014, 08:16:40 PM by Jims5543 »
« Reply #45 on: March 05, 2014, 07:10:33 PM »
Yes that's the choke.  I guess it's been warm enough you haven't needed it?
Offline Jims5543
  • 1380cc
  • Total likes: 363
« Reply #46 on: March 05, 2014, 07:25:45 PM »
LOL!! I would have probably started easier if I had known.
I set the idle to 1200 rpm it seemed happier there. I can also yank the choke to keep her running in a pinch.   ;D
We are expecting a really bad day weather wise tomorrow, but a really nice one on Friday so I am going to take her to work Friday.  Hope she does not shit out a con rod.
I need to start weighing my options for a new engine.
« Reply #47 on: March 05, 2014, 07:48:19 PM »
 :-[ yes Jim the choke makes things easy.  ;D.
Offline Jims5543
  • 1380cc
  • Total likes: 363
« Reply #48 on: March 05, 2014, 08:52:34 PM »
Out of curiosity, what RPM should I be idling at?
I noticed if I turned on the headlights is made her unhappy so I had to raise the idle, if I turn on the AC well, that is another can of worms. I would love to wire in a cycle switch to kick up the idle RPM when the compressor kicks in.
« Reply #49 on: March 05, 2014, 08:59:57 PM »
850-1000 range normally if memory serves me.  Most don't have tachs so it's whatever works.  Given that you have ac it's going to throw a curveball in there.
