I swore I had a timing light but cannot find it, gonna change the oil and then head to Harbor Freight and grab a cheap one since I will rarely use it anymore now that I have the 123 in there.
Quote from: Jims5543 on March 02, 2014, 09:41:33 AMI swore I had a timing light but cannot find it, gonna change the oil and then head to Harbor Freight and grab a cheap one since I will rarely use it anymore now that I have the 123 in there.If you are running a 123 dist. you do not need a timing light. It is set at zero degrees TDC and not moved after that. The 123 adjusts the timing as needed for each setting based on it being set at TDC.
