Heater hose routing
Started by Carl Owen, January 07, 2021, 01:49:33 PM
Carl Owen
Trying to tidy up hoses and wiring inside the car. Do the heater hoses go below the heater box? I'm only asking because looks like they may fit above the box.  Our Mini is RHD.
They will fit over the top, but then they have to make two tight 90* bends to get down to the nipples on the heater core and the hoses always seem to get in the way of the pedals - at least for me..
When I converted my Innocenti back to LHD, I reversed the heater core to come out the other side so the hoses were an easy fit. In your case you would have to drill a couple of holes in the case for the core nipples to come thru, but it would really make it neater and easier for the hose connections.
What car is this? You don't usually see the heater valve inside the car on a Mini.....
Carl Owen
Thanks MiniDave, I'll pull the heater box out and do that.
The car is a 1977 VTEC Clubman. I'm trying to figure out a place to squeeze the control valve in under the hood but may leave it tucked under inside. We also have to figure out a cable to operate it.
One thing I forgot to ask, is there an alternate source for the ducting to the defroster?
Other than the two hoses that go up to the defrost vents?
There's another alternative - there's an aftermarket heater assembly that works really well
http://www.minispares.com/product/Classic/Cooling_heating/Heating/Heater_matrix/C-ARA3000.aspx?070102&ReturnUrl=/search/classic/heater.aspx|Back%20to%20search
Dan put one in his Mini and he likes it.....
Carl Owen
Yes, I was talking about the 2 hoses (~1 1/4") going from the heater to the defrost vents.
I've been trying to find something locally to use to no avail.
Aha....I found some on a VW Beetle parts site.....
I like this VW stuff. Fits snugly enough that I did't use clamps. Slightly different than original with closer coils  but well made and excelent fit.
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D113%2D819%2D723%2DAL
Carl Owen
Oh. I like the look of that VW hose.  Nice !
Yes it's very well made and won't be mistaken for original. If one needs the original then a price must be paid for the original reproduction.
For my needs I just need something that works and if it looks good that's great.
I wonder if there's some other fresh air hose from some other car that would work for the Minis with the eyeball dash vents?  I'm talking about the big hose that runs from behind the grill up and into the right wheel well up to the firewall.
I would think a 4" dryer hose would work fine especially the silver metallic ones that you can form better than the plastic ones that came originally, but they won't have the foam inner sleeve.
Quote from: BruceK on January 09, 2021, 09:08:40 PM
Search flexible duct and size (DIA)
For the small defrost hoses a new shop vac hose for the little shop vacs works most hardware stores have them. Although that VW hose looks better or more correct.
The bigger stuff the NAPA here stocks a few sizes so I'm sure other NAPA locations could order it if they don't have it.
