Did a little port matching, now it's ready to go to the machine shop tomorrow morning. I could have it back by the weekend, and the rest of the bearings and small parts should be here by then too. I'll see about getting the paint and getting a coat of etch primer on so I can get the main color on too. The rest of this week should be warm enough to do some painting. When the transmission gets here mid-March I should be ready to joint them up and make some noise.That reminds me, I need to get the header off and get it ceramic coated too!
This engine is for the pickup I need to finish?
Quote from: MiniDave on February 28, 2021, 07:42:28 PMDid a little port matching, now it's ready to go to the machine shop tomorrow morning. I could have it back by the weekend, and the rest of the bearings and small parts should be here by then too. I'll see about getting the paint and getting a coat of etch primer on so I can get the main color on too. The rest of this week should be warm enough to do some painting. When the transmission gets here mid-March I should be ready to joint them up and make some noise.That reminds me, I need to get the header off and get it ceramic coated too!Nice work Dave.When Mike Guido built his engine for his GTM Mini based kit car he matched the intake up to the ports then with it bolted in place drilled two holes through the manifold into the head and installed roll pins as locaters.As there is wiggle room on the intake especially aftermarket ones I thought this was a good idea, similar to the rings they use on twin HS2's to align them to the ports.
Looks nice and smooth.
