Author Topic: Trouble finding / verifying new knuckles for Hi-Lo kit  (Read 645 times)
Offline ADRay
« on: October 15, 2020, 10:33:55 AM »
Hi all,
Iíve hit a bump putting the rear subframe back together. I have a used Minispares Hi-Lo kit (thanks George), and I thought I had located the correct knuckles for the kit. The ones I bought are too wide to fit in the receiving end of the ďtrumpetĒ. As I understand, they should just set in place, right?
I am not able to find the correct ones on Minispares (or anywhere), at least ones defined as a direct replacement and with a picture that doesnít look like the ones I have.
Any input is appreciated. Thanks.
1982 Mini 1000 HL
@andyray998
Online Willie_B
  • CREW
  • 1275cc
  • Total likes: 90
    • Lilburn, GA,
Re: Trouble finding / verifying new knuckles for Hi-Lo kit
« Reply #1 on: October 15, 2020, 11:32:05 AM »
You want just the regular knuckle joint. They will fit everything BUT the MiniSport Ho-Lo kit. That uses the larger end knuckles. Part number GSV1118MS on Minispares site. They also have the same part but with a poly boot for a bit more. We know how the latest rubber parts are holding up. I am about to order 4 of the poly types.
« Last Edit: October 15, 2020, 11:38:50 AM by Willie_B »
Offline ADRay
« Reply #2 on: October 15, 2020, 12:09:26 PM »
Thanks, that gives clarity to what I did wrong - I bought the Mini Sport knuckles for their kit (Adjust-a-ride).
1982 Mini 1000 HL
@andyray998
Online Willie_B
  • CREW
  • 1275cc
  • Total likes: 90
    • Lilburn, GA,
« Reply #3 on: October 15, 2020, 12:12:12 PM »
Another thing. Don't get the ones for 1990 and later, they have a built in spacer to raise the ride height.
« Reply #4 on: October 15, 2020, 01:54:03 PM »
I may have a pair of the MiniSport knuckles, they're used but not worn. Unless you just want new ones.....
Online Willie_B
  • CREW
  • 1275cc
  • Total likes: 90
    • Lilburn, GA,
« Reply #5 on: October 15, 2020, 02:10:21 PM »
His problem is he has the larger Minisport ones but needs the regular size ones. The larger ones are 14mm on the end to fit Minisport ho-lo's.
« Reply #6 on: October 15, 2020, 02:57:50 PM »
I probably have some of all three styles!   ;D
Offline ADRay
« Reply #7 on: October 16, 2020, 08:19:17 AM »
Thanks all. I am replacing all of the moving parts with new ones, so Iím compiling yet another order from jolly old England.
1982 Mini 1000 HL
@andyray998
« Reply #8 on: October 16, 2020, 10:17:39 AM »
Offline ADRay
« Reply #9 on: October 16, 2020, 10:21:12 AM »
Iíve been getting stuff shipped standard in under 2 weeks these day
1982 Mini 1000 HL
@andyray998
