Trouble finding / verifying new knuckles for Hi-Lo kit
Started by ADRay, October 15, 2020, 08:33:55 AM
ADRay
Hi all,
I've hit a bump putting the rear subframe back together. I have a used Minispares Hi-Lo kit (thanks George), and I thought I had located the correct knuckles for the kit. The ones I bought are too wide to fit in the receiving end of the "trumpet". As I understand, they should just set in place, right?
I am not able to find the correct ones on Minispares (or anywhere), at least ones defined as a direct replacement and with a picture that doesn't look like the ones I have.
Any input is appreciated. Thanks.
1982 Mini 1000 HL
@andyray998
You want just the regular knuckle joint. They will fit everything BUT the MiniSport Ho-Lo kit. That uses the larger end knuckles. Part number GSV1118MS on Minispares site. They also have the same part but with a poly boot for a bit more. We know how the latest rubber parts are holding up. I am about to order 4 of the poly types.
ADRay
Thanks, that gives clarity to what I did wrong - I bought the Mini Sport knuckles for their kit (Adjust-a-ride).
1982 Mini 1000 HL
@andyray998
Another thing. Don't get the ones for 1990 and later, they have a built in spacer to raise the ride height.
I may have a pair of the MiniSport knuckles, they're used but not worn. Unless you just want new ones.....
Quote from: MiniDave on October 15, 2020, 11:54:03 AM
His problem is he has the larger Minisport ones but needs the regular size ones. The larger ones are 14mm on the end to fit Minisport ho-lo's.
ADRay
Thanks all. I am replacing all of the moving parts with new ones, so I'm compiling yet another order from jolly old England.
1982 Mini 1000 HL
@andyray998
ADRay
I've been getting stuff shipped standard in under 2 weeks these day
1982 Mini 1000 HL
@andyray998
