But isn't the offset all wrong?Tire Rack does have a listing for a 155/80-13 tire, and a 165/70-13.
Just found this very exhaustive list of Mini wheels. Hundreds of them. Interesting viewing. https://www.wheeldictionary.net/10a.html
Quote from: BruceK on July 31, 2020, 11:56:06 AMJust found this very exhaustive list of Mini wheels. Hundreds of them. Interesting viewing. https://www.wheeldictionary.net/10a.htmlAll 10's tho.....
Thought this was my wheel on my kitchen counter at first.
Quote from: 94touring on July 31, 2020, 12:00:42 PMThought this was my wheel on my kitchen counter at first. You have a set of CMW wheels Dan? I have a set that has never been put together or even drilled for the valve stem. Need lug nuts for them.
Even with 12" wheels, you have to be mindful of the diameter.The "cheaply available" 12" tires are 155/80/12 sized and that results in a 21.76" diameter. This should not be a problem for the fronts, but may still have a rubbing issue for the rears.
The truck use to sport 12 inch steelies.
Quote from: MPlayle on July 31, 2020, 01:42:29 PMEven with 12" wheels, you have to be mindful of the diameter.The "cheaply available" 12" tires are 155/80/12 sized and that results in a 21.76" diameter. This should not be a problem for the fronts, but may still have a rubbing issue for the rears.So, a small spacer or a set of Cooper S drums should take care of that, right?
Quote from: MiniDave on July 31, 2020, 02:14:32 PMQuote from: MPlayle on July 31, 2020, 01:42:29 PMEven with 12" wheels, you have to be mindful of the diameter.The "cheaply available" 12" tires are 155/80/12 sized and that results in a 21.76" diameter. This should not be a problem for the fronts, but may still have a rubbing issue for the rears.So, a small spacer or a set of Cooper S drums should take care of that, right?I think the problem won't be the offset, but the overall diameter of the tires will cause them to rub on the radius arms in the rear.
