Author Topic: Spiral Cut Reamer 1-19/64  (Read 354 times)
« on: April 12, 2020, 04:01:44 PM »
I need this odd sized reamer to ream the rear bushing in Sprite transmissions.....at least I think that's what I need. The stub of the driveshaft measures 1.285, 1-19/64 is 1.296875, 1-5/16 is 1.3125, that seems like a pretty big gap.
1.296875-1.285 = .01875
1.3125-1.285 = .0275
I can't find any sizes or specs on what the hole size is supposed to be, but that is a weird size reamer - I haven't been able to find a spiral cut adjustable either. A straight cut won't work because there's a split in the bushing so you can press it into the housing.
Anyone have any ideas?
Offline John Gervais
Re: Spiral Cut Reamer 1-19/64
« Reply #1 on: April 12, 2020, 07:17:04 PM »
SpridgetGuru has a lot of downloadable reference books and I tried to upload a couple of .pdf's, but they're too big.
Perhaps the specification or tolerance is in here?
http://www.spridgetguru.com/AKM0036/AKM0036.pdf
Or, in the library?
http://www.spridgetguru.com/Spridget_Books.html
« Reply #2 on: April 12, 2020, 08:40:41 PM »
The first link is a parts book, which I'm grateful to have as the illustrations are much clearer than anything I've found up till now, but doesn't help with any specs that I could find in a quick look. I've downloaded it to save for now.
While 33mm is slightly bigger than 1 19/64, I doubt they were using metric reamers back then......I've got some calls out to specialists who build race boxes, I'll see what they come up with too.
thanks guys!
Offline tsumini
« Reply #3 on: April 12, 2020, 11:41:21 PM »
Will a 1 9/32 spiral reamer (available) work for initial cut 1.2812 (0.004T)? Then use the straight adjustable for the final 0.005 to get 0.001L.
I used an adjustable reamer for the radius arm bushing and had the hangup problem on the bushing split so I found that turning it backward would cure that problem but that is on bronze material. You didn't say what material you had to ream.
I also presume you  need loose fit after bore.
