Woody wagon project
Started by macmanron, March 28, 2010, 08:04:18 PM
macmanron
Call me Wed. I have work all Day, and kids to pick up in the afternoon, but after 5:00pm I'm good to go. Unless you get with me earlier in the day. I have a window of about 10am till 2:15 wed.
Ok I'll be dropping her off around 5.
macmanron
macmanron
got my spot welder in from Harbour Freight!!! Now to get SERIOUS!!!!!!!!
MiniGene
ronjern
Well, I'm back after all this time!!! I had to re-register!  Progress on the wagon again. I will post pics soon.
ronjern
Here are some pics, been working on the Wagon quite a bit more.  front floors in, both A-Panels inner and outer in, both wings on, new cross member in, door steps in too. now, just trying to figure out the back bits where the subby bolts up to the Heelboard. need to figure out how the bits in the companion bins go. I guess they are stiffeners??  Once I get that figured, then the rockers, and next the rear of the car. After that, time to start sanding etc. here is a link to the pics:
the first pic is when i had just gotten it apart, not sure why that is there:
<iframe width="480" height="360" src="http://s444.photobucket.com/user/macmanron/embed/slideshow/"></iframe>
Need me to reset your password or something?
Looks like you got your scuttles to fit.
ronjern
yes, a bit of fiddling with them, and some filler, this is a driver not a museum piece. Need to order some small panels now, just fiddly bits, and the inner rear valance. Other than that it's going along pretty well. Just have to get the rear subby to the body part done correctly.
macmanron
shop computer still logs in!
Lol you probably still can log in from other devices but I've had a bug for years I never figured out that will occasionally not allow you to login on the first attempt or two even if your user name and password is correct.  No clue why.  Try clearing cookies and cache on your other devices.
While serving as admin for the MOT forum, I found that there is an underlying "glitch" in the SMF software that causes issues with using the login fields that appear on the home page.
If you click the "login" tab on the menu bar and use the screen that brings up, it will work almost every time.  I am now in the habit of always using the login tab.
Quote from: MPlayle on November 26, 2013, 08:23:23 PM
At least I'm not the only one with this problem!
