Spring will be in the air soon. Time to build engines.
Started by CooperTune, March 12, 2020, 09:33:45 AM
CooperTune
I'd like to build a couple of engines to sell. I have parts for most any combination. I bore clean and hone cyls. polish or grind crankshaft. I use two part Cooper balancer and light flywheel pre or Verto. complete assembly balanced. Pre assemble check piston to deck and have block surfaced to correct. New core camshaft to match use. As for heads I like 295 castings for my small bores. 940 casting for 1275 based units. All heads get cleaned crack checked guides, new valves and hard exhaust seats. CC ed and surfaced to set compression ratio springs to match cam. Porting is optional or spec heads can be ordered. If you have any interest please contact me. Steve (CTR)
Forgot to mention I have A and A+ 998 and 1275 cores as well as a 998 Cooper core.
