Author Topic: I find myself with several 3.44 CWP sets A and A+  (Read 572 times)
Offline CooperTune
« on: December 27, 2019, 05:38:37 PM »
I have several sets of 3.44 CWP in both A and A+. These have been removed and tie wrapped is sets. Asking $100. per set to include shipping in US. I also have some posi CWP sets in different ratios. They are a little more expensive but I'll need to check what I have. Steve (CTR)
Re: I find myself with several 3.44 CWP sets A and A+
« Reply #1 on: December 27, 2019, 07:38:51 PM »
Do you have any taller ratios? especially a 2:76 or 3:0?
Offline tmsmini
« Reply #2 on: December 27, 2019, 08:20:48 PM »
Dave:
If Steve does not have any, I have some 2.76.
Terry
« Reply #3 on: December 27, 2019, 09:06:56 PM »
I believe I still have a 3.1 set.
Offline CooperTune
« Reply #4 on: December 28, 2019, 08:14:59 AM »
No I'm short on 2.95 and 2.76 which have filled the spaces the 3.44s came from. I do have over drive drop gears both primary and input gears. Using a 2.76 and two O/D drops I run some where in the 2.56 range 70 MPH at 3000 RPM. Using the ultra wide ratio gear set I can still spin the fronts off the line. Power unit requires torque to make the 1000 RPM step between gears. Third gear is pretty much the same as 3.44 and works well to about 50 MPH. Steve (CTR)
Offline TDA
« Reply #5 on: December 29, 2019, 09:02:29 AM »
Steve,
I am looking for a posi CWP in a ratio arount 3.7 to 1.  Let me know if you have a LSD CWP that might work for me.
Thanks,
Tim Allen
Offline CooperTune
« Reply #6 on: December 29, 2019, 09:24:22 AM »
I'm fairly sure when I started using 3.7 CWP s in our Vintage cars I replaced all the 3.9s.  When Nick came over and drove our car to a Group win in the Gold Cup he was impressed with the 3.7 and went back to the UK and had some made for his use. I should have some REM treated 3.9 sets and a new Trannex posi as well as NOS JKD standing start dog set and a Swift rolling start dog set all new for rod change. Have Hardy Spicer or pot diff. out puts and side covers for posi. Steve (CTR)
« Last Edit: December 29, 2019, 09:32:48 AM by CooperTune »
Offline CooperTune
« Reply #7 on: December 30, 2019, 04:17:20 PM »
Looks like I have a pair of 3.9, 1 4.13 and 1 4.20 for posi. One  2.95, 1 3.2 , 2 3.1, 1 3,65, 1 3.76, 1 3.9 and several 3.44 std CWPs. Steve (CTR)
2.95 CWP now sold.
« Last Edit: February 03, 2020, 08:26:25 AM by CooperTune »
