Blown Head Gasket Made Worse
Started by Rosebud, November 18, 2019, 10:35:55 AM
Those look like "rim flow" valves, spendy....
Rosebud
Rosebud
...the sled, not the flower
Rosebud
Quote from: MiniDave on November 18, 2019, 12:35:07 PM
Spendy and hard to find. Plenty of 1 collet grove versions available. I needed a 3 grove version and those were very hard to source.
Rosebud
Rosebud
Video: https://youtu.be/Nz28jIrrses
Not exactly a "how to." More of a precautionary tale...
Rosebud
#7
I've never seen one blow like that where there wasn't a contributing factor, and not just 10:1 compression. Usually like you said, a head that isn't flat or a block that isn't - although it's usually the head. You didn't see any gaps when you put a straight edge on it?
Looks like you're running 1:15 roller rockers, make damn sure you're not getting coil bind at full lift with those - that can cause all sorts of issues.....I would want to know why the valve bent - was there any indication that it hit the piston?
Interesting sound track - what the heck is that? Nevermind, found it in the comments.
Rosebud
Quote from: MiniDave on November 18, 2019, 01:11:51 PM
Head and block are flat, ARP studs were torqued correctly. Had <20k on the odo. The valve hit the piston when I was adjusting the valves and rocking the car back and forth. Read the article for the backstory: https://www.facebook.com/notes/poser-motorsports/blown-head-gasket-made-worse/3168054043267250/
Rosebud
ok, that wasn't clear in the article.....
