Author Topic: Leaky head gasket (not blown)  (Read 642 times)
Offline ADRay
« on: April 27, 2019, 09:36:42 AM »
It appears that I have oil leaking from between the head and the block. Iíve looked at the oil & coolant and they are both clean.
I need to do something about the oil leak. Is there anything short of replacing the head gasket that I can do? Thinking in terms of stop-leak products... does such thing exist? Thanks
Re: Leaky head gasket (not blown)
« Reply #1 on: April 27, 2019, 10:35:01 AM »
Check torque settings and then replace said gasket if it still leaks.
« Reply #2 on: April 27, 2019, 10:47:55 AM »
I agree - retorque the head first (don't forget to recheck the valve clearances) and see if that takes care of it. If not - replace the head gasket.
I don't know of any stop leak product that would stop a head gasket leak, those are mostly designed to swell seals up and help slow leaks from seals, not gaskets.
Offline ADRay
« Reply #3 on: April 27, 2019, 11:28:09 AM »
Ah, ok. thank you gentlemen.
