Author Topic: Grille buttons  (Read 299 times)
Offline ADRay
Grille buttons
« on: April 11, 2019, 10:56:38 AM »
Iím sure most of you have seen these before. I picked these up from Mini Sport for around $10. Before that, the grille was held on by 2 screws, a zip tie and a prayer. Install was easy, and they are not only functional, but look pretty sharp too.
1982 Mini 1000 HL
Re: Grille buttons
« Reply #1 on: April 11, 2019, 10:18:24 PM »
I have them on my car too, and while it sure makes it easy to take the grill out and replace it, you have to be careful you don't crush those slats by overtightening, or lose one of the nuts by undertightening. I've done both.... ::)  :(
2004 Audi Allroad 2.7 TT
Offline ADRay
Re: Grille buttons
« Reply #2 on: April 12, 2019, 06:34:10 AM »
yes, I have been checking them after drives, still tight. I also positioned the posts to go through the vertical steel braces of the grille, so there is a little bit of reinforcement for the aluminum slats. My grille is already a little wavy in some sections too.
1982 Mini 1000 HL
Offline Jimini II
Re: Grille buttons
« Reply #3 on: April 13, 2019, 11:27:50 AM »
After buying a few sets of grille buttons for several Minis i now use riv nuts with stainless phillips head screws in between the slats so there is no pressure on the slats and you can't see them once installed.
Offline jeff10049
Re: Grille buttons
« Reply #4 on: April 15, 2019, 12:21:57 AM »
My grille is also wavy.
Offline ADRay
Re: Grille buttons
« Reply #5 on: April 15, 2019, 06:22:28 AM »
the right kind of wavy
1982 Mini 1000 HL
Offline thebluepotato
Re: Grille buttons
« Reply #6 on: June 27, 2019, 08:28:51 AM »
I love mine....and in fact, I lost one last year and didnt realize that you can buy these individually from MiniSpares, sport, etc.  Saves me a TON of time when working on the front.
