Author Topic: 10" cosmics  (Read 742 times)
Offline 94touring
10" cosmics
« on: November 01, 2018, 06:44:05 PM »
A little rough around the edges but will refurbish nicely.  $150 OBO.  Need them gone to clear shop space.
Offline jedduh01
Re: 10" cosmics
« Reply #1 on: November 02, 2018, 08:37:22 AM »
Will they take "normal" lugs = like round or tapered seat?  Or do they require a 'shouldered lug"   - do you have lugs I guess is other question.
Offline 94touring
Re: 10" cosmics
« Reply #2 on: November 02, 2018, 10:03:47 AM »
I don't have any lugs for it, at least not a full set.  It has a small taper and seems to use the same angle I have on my force and jbw wheels. I put a lug on the taper to see how well it matched up.  Pic if it helps.
Offline jedduh01
Re: 10" cosmics
« Reply #3 on: November 02, 2018, 10:37:14 AM »
Offline 94touring
Re: 10" cosmics
« Reply #4 on: November 02, 2018, 10:38:24 AM »
Re: 10" cosmics
« Reply #5 on: November 02, 2018, 11:01:06 AM »
That's actually a good price on those lug nuts, Spares wants  1.50 each for those same nuts, so 24 for 16 nuts which is $32 at the current exchange rate, close to same price as 7Ent wants, first time I've seen them competitive - on anything!
2004 Audi Allroad 2.7 TT
Offline kcmini
Re: 10" cosmics
« Reply #6 on: November 02, 2018, 04:01:46 PM »
you need to donate them to the British transportation museum .org for Hrach s Mini  van that was donated that wellers on it that don't look the part
go check it out under cars
« Last Edit: November 03, 2018, 12:16:11 AM by kcmini »
Offline TDA
Re: 10" cosmics
« Reply #7 on: November 08, 2018, 10:11:53 AM »
Are these still available?
Are they 4.5" or 5" wide?
Do you know what the off-set/back spacing is (ET ??)?
Let me know.
Thanks!
Offline 94touring
Re: 10" cosmics
« Reply #8 on: November 08, 2018, 10:44:22 AM »
Here's what I'm showing.
Re: 10" cosmics
« Reply #9 on: November 08, 2018, 11:01:53 AM »
Let me know.
Thanks!
Hey TDA, are you Jim's brother?
They're 5", you measure between the beads
« Last Edit: November 08, 2018, 11:04:58 AM by MiniDave »
Offline 94touring
Re: 10" cosmics
« Reply #10 on: November 08, 2018, 09:01:01 PM »
Here they are on a car.
Re: 10" cosmics
« Reply #11 on: November 08, 2018, 09:41:34 PM »
Wow, that's Vikram's "before"?
Offline 94touring
Re: 10" cosmics
« Reply #12 on: November 08, 2018, 09:42:19 PM »
Yeah, old and green!
Offline Vikram
Re: 10" cosmics
« Reply #13 on: November 09, 2018, 01:24:02 AM »
Offline TDA
Re: 10" cosmics
« Reply #14 on: November 16, 2018, 09:49:33 AM »
Do you know if these wheels will fit over 7.5" disk brakes?
Did the green car that the wheels are shown on have drum brakes?
I'm guessing these wheel would stick out a long way on a disk brake car but I am not sure.
Let me know.  Thanks, Tim Allen
Offline 94touring
Re: 10" cosmics
« Reply #15 on: November 16, 2018, 10:17:55 AM »
Tim, I'll mount them on my car with disc next week and snap a photo for you.  I don't see why they won't fit but the offset will be greater since the green car had drums.
Offline 94touring
Re: 10" cosmics
« Reply #16 on: November 29, 2018, 10:03:37 AM »
Finally out at the shop after the holidays and job #1. Here they are mounted on spaced drums you'd pair with disc.  There is a 3/4" body gap running a straight line.
Offline 94touring
Re: 10" cosmics
« Reply #17 on: November 29, 2018, 01:28:20 PM »
Oh and yes they fit over disc
Offline Vikram
Re: 10" cosmics
« Reply #18 on: November 29, 2018, 03:56:21 PM »
