Author Topic: 73 Mini Innocenti 1300 Export  (Read 66367 times)
« Reply #500 on: May 08, 2019, 02:56:16 PM »
While Dan's finishing up the fuel tanks and some other bits and bobs, I drove the 2 hour round trip up to the crank shaft guy again, to find out if our stroked crank was any good - which it is - and to find out if he was going to have to grind the mains and rods - which he's not. I also had weighed out the rods and the heaviest to the lightest was only 6 grams. These rods are also considerably lighter than the other ones I was going to use - 680 vs 740 - so we've added some more lightness to the rotating mass.
I also ordered the new primary gear, main and rod bearings and a few other bits - to the tune of yet another $300!
Oh well, in for a penny as they say......many, many, many, many pennies in this case, and more than a few pounds too!
Newton Commercial confirmed that the interior bits are still another 4 weeks away, so there's no way this car is going to Snowmass this summer, so I'll need to do a bit of spiffing up on the Racing Green one before I hit the road west towards the end of June.
This is the sign on the front desk of the cranky shop....
Once the gear comes in I'll take all the rotating bits back up there to be rebalanced to this crankshaft, it shouldn't take much as everything but the clutch and flywheel were on there to start with.
« Last Edit: May 08, 2019, 03:04:51 PM by MiniDave »
Offline gr8kornholio
« Reply #501 on: May 08, 2019, 03:12:08 PM »
You'd think with those kind of wait times that the machining business is ripe for another place of business.  They are so hard to find, even in major metropolitan areas.  Guessing the skills and equipment are a dying breed.
Offline 94touring
« Reply #502 on: May 08, 2019, 04:48:14 PM »
Tanks be done
« Reply #503 on: May 08, 2019, 04:50:06 PM »
Yeah, there used to be 4 or 5 shops here in town, now there's just the one.....
The equipment is very expensive, and it takes some training to operate it correctly, and it's really expensive if someone screws it up.
Tanks look SO much better....
Offline 94touring
« Reply #504 on: May 09, 2019, 10:12:08 AM »
Loosely into place.  Much better than before.
« Reply #505 on: May 09, 2019, 11:01:33 AM »
That left side tank is huge!  Is that factory?  Looks like a spare wouldn't fit.
« Reply #506 on: May 09, 2019, 12:17:41 PM »
Yes, that's the factory 9 gallon (7.5 Imperial) tank, it wouldn't have been used with the right side tank, so we know it's an add on. 14 gallon total capacity! I could drive from here in KC to the western edge of Kansas on one tanks full.
The spare tire fits up under it, but a 6" wide 13 won't go! Only 10's, maybe a stock 12...
« Reply #507 on: May 09, 2019, 12:27:53 PM »
Ok, I see the indentation for the spare, that shiny black makes it hard to see.  Um, with the HOT motor you're building for this you think it'd still get that mileage?  71.gif  I never tracked mine on my 1380.
« Reply #508 on: May 09, 2019, 12:33:06 PM »
No idea, but on light cruise it should do OK. Dan's engine will do 30 mpg, except he can't keep his right foot out of it!  :-)
That and the tall gears will help too, but then we're not really building it for gas mileage - if I have a long ways to go I'll tow it - the tow car gets around 25-27 while pulling it.....
Dan, you have some of that red paint left for touch ups?
Offline 94touring
« Reply #509 on: May 09, 2019, 02:36:36 PM »
It's a pretty cool build when you figure it's a luxury interior with extended range tanks, plus the very hot motor.  Best of all worlds. Will be comfortable to drive and haul butt.
Yeah some leftover paint.
Filters oiled with K&N oil.  Before and after.
Offline Jimini II
« Reply #510 on: May 09, 2019, 02:59:50 PM »
Coming along nice guys someone is going to get a really nice Inno at the end of this build, that is if you sell it of course.
Is that the correct way for the carb to carb adjustment linkages to be installed? All the UK ones are installed with both the nuts facing up.
Just my ocd kicking in LOL.
« Reply #511 on: May 09, 2019, 03:01:31 PM »
Who knows? That's the way they came apart, but I haven't had it back in the car yet to see how it should sit. What part looks wrong to you so I know what to look at when I get it back?
Offline 94touring
« Reply #512 on: May 10, 2019, 09:21:47 AM »
On the linkages the bolt and nut combos that clamp things down should have the nuts up.  I noticed it when I first got the carbs but forgot till Jimini pointed it out.  If you have to make adjustments you want the nuts facing up.
Offline Jimini II
« Reply #513 on: May 10, 2019, 09:24:22 AM »
The two linkages (rods) that connect the carbs together have the adjusters on each end.
The nuts should all be facing upwards so you can adjust each end with ease and not burn your hands on the exhaust.
It will work the way you have it as you only really need to be able to loosen one end to get everything adjusted but to be correct they should both be facing up.
Well at least that is the way the UK cars were fitted.
« Reply #514 on: May 10, 2019, 09:52:10 AM »
Got it, that's an easy enough fix, just take it out and turn it over.....or maybe even easier, just take the bolts out and turn them over? or does the linkage have a way to hold the heads of the bolts, so they have to go in only one way? I'll have to look at them when they come back......
« Last Edit: May 10, 2019, 09:54:31 AM by MiniDave »
Offline 94touring
« Reply #515 on: May 10, 2019, 10:19:29 AM »
We can look when I bring it up next week.  It's a simple fix, especially off the car.
« Reply #516 on: May 10, 2019, 02:08:09 PM »
I'm making up a list of things to make sure you bring with you.....I'll email it to you
Offline Jimini II
« Reply #517 on: May 10, 2019, 05:52:31 PM »
I believe you can just turn the bolts over no need to remove a carb.
« Reply #518 on: May 13, 2019, 01:16:51 PM »
While waiting for MiniSpares to get off their collective asses and send me my parts, I put a straight edge on the block and sure enough I could see light under the edge at the junctions between the cylinders, so I ran the block back to the machine shop to have them surface the deck, it won't take much, just a couple thou but that will give us the straight flat surface we need to hold the gasket. The head was already surfaced at the cylinder head shop.
Offline 94touring
« Reply #519 on: May 15, 2019, 08:32:08 AM »
Headed back to Daves.
Offline MiniGene
« Reply #520 on: May 15, 2019, 09:24:24 AM »
Looks great!  At first glance I thought you had installed those "white/clear" boy racer tail lights!  Good catch folding the mirrors in so the wind blast doesn't push them backwards.  I probably would have never thought of that.
This has been a fun build to follow.
« Reply #521 on: May 15, 2019, 09:31:22 AM »
Sure looks "redder" in the daylight than the shop lights....looks fantastic!
« Last Edit: May 15, 2019, 09:42:08 AM by MiniDave »
« Reply #522 on: May 19, 2019, 07:32:56 PM »
Working on the back end, got all the wiring to the lights sorted, the taillights installed and the right side tank in, along with the Monza fuel cap. Doesn't sound like much but there are a hundred little jobs leading up to this point, painting the tank retaining strips, new gaskets under the hinges, sorting the wires and so on. I still need to install the fuel cross pipe and hoses. I couldn't find another 2" 5/16 -24 bolt for the retainer strap so I made one out of a piece of all thread.
Tomorrow I'll get the left tank installed and trimmed out, the sending unit installed, the fuel pump installed and wired up and the  em. brake cables installed. Once the back is buttoned up I'll move up to the front and start working on the front wiring harness and lights while I'm waiting for the engine parts to come back from the crank shop.
« Last Edit: May 19, 2019, 07:36:27 PM by MiniDave »
« Reply #523 on: May 21, 2019, 07:04:01 PM »
Both tanks in now, both Monza caps installed, cross pipe in...all I need to do now is install, wire and plumb the fuel pump....but first I want to bench run it and make sure it will pump fuel. While I'm down there I'll install the emergency brake cables, rear brake line and red + cable to the battery.
« Reply #524 on: May 23, 2019, 08:57:24 AM »
More news.....None of the fuel pumps I have work, it looks like the one that was in the Innocenti was one of the newer electronic pumps, no points I can replace so it's dead. I have a larger spare off my E-Type but it's dead too. Should have checked it earlier I guess.
So, now I have a new pump on the way. I can get one from Victoria British but theirs is really expensive now - which is curious as I've bought them before and did not remember them being nearly this high.
In the meantime I'll finish up the emergency cables - does anyone know if there is a fairlead gasket on both the top and bottom of the body where the cables pass thru? Also, I have a couple of springs that look like they go on the cables at the handle end? I know about the ones at the brake backing plate end, but were there some at the front too? Anyone have a pic?
Lastly, a little bit of good news - the interior has shipped from Newton Commercial today!  4.gif
