Author Topic: 73 Mini Innocenti 1300 Export  (Read 11748 times)
Online MiniDave
« Reply #425 on: April 03, 2019, 08:13:42 PM »
I'm pretty happy with the look too, tomorrow I can turn it over and paint the other side.....
Weighed out the pistons just for fun - all 4 were within 1 gram of each other 2 @ 424 and 2 @ 425 grams
The rods varied quite a bit @ 741, 734, 736 and 731 grams although the big vs small ends were very consistent.
I don't know what taking so much weight off the flywheel does to the balance - my guess is nothing as long as the flywheel itself is balanced - but our new one weighs less than half what the original does. I'll send it, the clutch assembly and the front damper, along with the rod bearings, rings and bolts with the crank and he can set it all up.
2004 Audi Allroad 2.7 TT
Online MiniDave
« Reply #426 on: April 03, 2019, 08:26:58 PM »
  We won't need 1.5 rockers, but ditched the stock sintered rockers that spec at 1.21 and went with forged S which are a true 1.3, and would have been period correct.
You used to be able to buy offset bushings for the forged rockers that will bump them up to 1:15
Online MiniDave
« Reply #427 on: April 04, 2019, 05:24:24 PM »
This is why when doing an overhaul you always remove the oil pressure galley plugs.....this is the oil pressure relief plunger - it's scarred so badly it looks like they ran metal scrap thru it. The rearmost cam bearing was trashed too, along with the cam and lifters. The plunger was stuck in the hole, but a 1/2" coarse tap just fits it perfectly - I only had to thread it in a turn or two and the plug began to move and I was able to get it out.
So I'll pull the galley plugs and clean it all out, I already have new cam bearings and a new oil pump is on the way along with the new cam and lifters. I also have a new plunger and spring for it. Haven't decided whether to thread the holes with a pipe tap and use grub screws to seal them off or just tap in a new set of galley plugs the way they are now.
There is so much more to rebuilding an engine properly than just putting new bearings and gaskets in it.
Online gr8kornholio
« Reply #428 on: April 07, 2019, 11:50:23 AM »
Dave, was that the POR 15 Engine Enamel that you used?  I'm not sure if I want my engine that glossy.  The POR I have is more satin, but not sure if it'll handle engine temps.
Online MiniDave
« Reply #429 on: April 07, 2019, 12:31:53 PM »
Yes, engine enamel - I like the shiny!   ;D
But it does tone down a bit once it cures out.
Besides, most of it is hidden under all the other stuff attached to the engine.
If you're using chassis black, it tends to chalk up I'm told. It doesn't affect the protection, just the looks.
Wonder if they sell it in pints as well as quarts - a little goes a long way with this stuff. I wish I would have had an airbrush....even tho it lays out perfectly smooth, I think it would have been easier to paint as compared to a brush.
Next up I need to clean the block thoroughly, all the nooks and crannies, all the oil passages etc, then it will be ready to build. You can't just clean them with solvent, you also need to clean them with degreaser, soap and lots of water, then you have to immediately dry it and coat the machined surfaces with something so they don't flash rust. It's a lot of work, but the results are worth it - if you don't your engine rebuild will only last about 10K, then you get to do it all again.
« Last Edit: April 07, 2019, 12:38:39 PM by MiniDave »
Offline 94touring
« Reply #430 on: April 07, 2019, 01:42:27 PM »
They sell it in pints. I'm sure you can spray it, but you'd need a petty big tip.
Online gr8kornholio
« Reply #431 on: April 08, 2019, 07:01:07 AM »
Since the block came back painted, what if anything did you do to the block before painting with POR?  I'm sure mine will need a good cleaning.
Offline 94touring
« Reply #432 on: April 08, 2019, 07:03:29 AM »
All that's required is a good cleaning to make sure it's grease free.
Online MiniDave
« Reply #433 on: April 08, 2019, 09:12:17 AM »
Yeah, that stuff really bonds with the metal.....the few places where I got a drip I had to use a razor blade to scrape it off - it was on there good!
The shop that honed the cylinders cleaned it in their hot tank after they did the machine work, then I cleaned it in my solvent tank, then spritzed it down with 409 and water, then I wiped it down with lacquer thinner. Probably overkill.....
Took the crank, rods, pistons, flywheel and clutch assembly et all up to the crank guy to be balanced. Funny, every shop I take stuff to says the same thing......2 weeks!
« Last Edit: April 08, 2019, 03:47:20 PM by MiniDave »
Online MiniDave
« Reply #434 on: April 09, 2019, 12:18:03 PM »
The new camshaft that arrived yesterday came with the springs recommended to be used with it, so I took them down to the cylinder head guy hoping that they didn't already have it back together.....HA!
They did have it disassembled and cleaned (don't know why they felt the need to hot tank it, I had cleaned it thoroughly before I took it down there) and he said later today they would check it for cracks and tomorrow give me a list of the parts they needed - valves and seals  - or whether they could use the valves in the head now. I don't know if the ones they sell at Vicky Brits will be the larger 35mm intakes or smaller ones commonly used on a Sprite, need to find out or else there will be a further delay while I order them from Spares.
Anyway, he said they might be done with it in another 2 weeks to a month!
Yikes! Gonna make it tight for getting it back together, run in and ready for Aspen/Snowmass. I might be taking the green Mini after all.
« Last Edit: April 09, 2019, 12:21:54 PM by MiniDave »
Offline Jimini II
« Reply #435 on: April 09, 2019, 02:42:09 PM »
just a thought based on the 2 weeks to a month statement i would have a back up cylinder head to use for Snowmass.
Offline 94touring
« Reply #436 on: April 09, 2019, 02:54:21 PM »
I do have a stock 940 head on the shelf.
Online MiniDave
« Reply #437 on: April 09, 2019, 03:44:36 PM »
I do too, just in case.....but there is a lot more to do than just the head. Worst case I'll take my green 89 Mini.
They called just after I got home to say I needed all the valves, guides and seals. I had to order valves and a timing chain from Spares, it had 35.7mm intakes and 31mm exhaust, those are bigger than anything Vicky Brits had.
I think all my recent calls and visits may have pushed them a little, Ima keep it up! I already took the guides and seals down to them, but I let them know I wouldn't have the valves till probably Monday.
« Last Edit: April 09, 2019, 03:48:36 PM by MiniDave »
Offline 94touring
« Reply #438 on: April 15, 2019, 05:25:50 PM »
Wheel caps are in, hoping they fit without any fuss.
Online BruceK
« Reply #439 on: April 15, 2019, 05:55:13 PM »
They look great
2007 Triumph Bonneville
Offline 94touring
« Reply #440 on: April 16, 2019, 10:47:14 AM »
Ok minimal fuss.  The tabs on these caps didn't work with the wheels.  So I broke them off and turned down the caps till they fit.  Much improvement over the old hand painted ones.
Offline Jimini II
« Reply #441 on: April 16, 2019, 02:16:48 PM »
Nice. Those little things and attention to detail make all the difference in the finished product.
Offline 94touring
« Reply #442 on: April 17, 2019, 11:00:08 AM »
Ready for it's new hairdo.
Online BruceK
« Reply #443 on: April 17, 2019, 11:46:02 AM »
Pepper White (850) ?
Offline 94touring
« Reply #444 on: April 17, 2019, 12:33:34 PM »
You even know the number!
Online BruceK
« Reply #445 on: April 17, 2019, 03:41:26 PM »
850 is an easynumber to remember for Mini enthusiast!
Offline 94touring
« Reply #446 on: April 17, 2019, 04:52:03 PM »
Much better!
Offline 94touring
« Reply #447 on: April 17, 2019, 04:56:21 PM »
A view showing the beige interior against the roof.
Online MiniDave
« Reply #448 on: April 17, 2019, 05:03:11 PM »
Offline Jimini II
« Reply #449 on: April 18, 2019, 08:53:20 AM »
Nice work looks a lot better with that more subdued white.
Looking at the gutter in that picture it seems like the Inno's did the larger drain cut outs a lot earlier than the UK models.
