Author Topic: 73 Mini Innocenti 1300 Export  (Read 63907 times)
« Reply #75 on: November 03, 2018, 02:44:09 PM »
That's right, I remember seeing the twin exhaust on your Moke now.....
I think we've decided on a Maniflow twin box with twin center pipes, still kicking it around
Offline Vikram
« Reply #76 on: November 03, 2018, 04:36:06 PM »
Twin centre pipes look great! Going to do that on mine eventually.
« Reply #77 on: November 03, 2018, 06:55:15 PM »
And it's out! Bulkhead looks great too......tomorrow I'll get the engine mounted in my engine stand and see if I can make it run...might not be able to as it has a bad starter.
« Last Edit: November 03, 2018, 07:11:39 PM by MiniDave »
Online 94touring
« Reply #78 on: November 03, 2018, 07:40:49 PM »
Moving right along!
Offline drmini
« Reply #79 on: November 04, 2018, 12:48:17 PM »
I have redrawn the Innocenti wiring diagram in full colour with English names, etc.  I did this several years back when I was rewiring the 1300 Export for a customer's car.  I would be happy to send you a copy.  I have it in AutoCAD, but can have it converted to some other format if you can't open AutoCAD dwg files.  Email me with your request along with the preferred format.  FWIW, I also have several UK Mini wiring diagrams in colour as well.  Cheers, Hugh
Offline drmini
« Reply #80 on: November 05, 2018, 11:07:25 AM »
Now that the engine bay is empty, did you find the VIN stamped into the RH inner wing?  Just curious if it matched the number on the incorrect plate and the window etchings.
Online 94touring
« Reply #81 on: November 05, 2018, 11:22:14 AM »
Negative on the wing. But the Parnell book shows the German built having the plate on the carpet under the pax seat.  It also shows one on the slam panel in one photo.  Hugh I think it's a new shell considering 1 paint job, no metal work, virtually no rust anywhere, and the fact it's a 73 with single bolt subframe, wing washer bracket, and outter bonnet hinges.  What do you think?
« Reply #82 on: November 05, 2018, 12:39:06 PM »
Got some more errands done on the Inno this AM, my lock and key guy actually had a blank for the ignition key, so he's going to cut new keys for us by the codes rather than copy them. I was amazed he had a key blank for the ignition as it's an Arman key, one I'd never heard of but is used on Fiats and Citroens.
DrMini kindly sent me his redone wiring diagram so I went to Kinkos and had it enlarged to 11X17 so my poor tired eyes could read it - they also laminated it for me!
Today I'll get the engine wrassled out of the subframe and into the engine stand......it's a rainy gloomy day with snow forecast for later in the week, perfect weather for working in the shop!
I have a substantial order in the cart at MiniSpares, just waiting for me to push the go button but I'm going to give it a few more days in case I think of other things we need, I know I'll be finding other things I forgot 5 min after I push the button.
« Last Edit: November 05, 2018, 02:36:08 PM by MiniDave »
Offline drmini
« Reply #83 on: November 05, 2018, 02:19:39 PM »
Glad you were able to copy the wiring diagram.  11 x 17 seems small to me given the amount of lines and information on the drawing.  Just out of curiousity, what did it cost to do the laminated 11 x 17?  Were the colours good/readable?  I unfortunately, the White wires probably print in black same as the Black ones, but have a W all over them.  On the UK wiring diagrams I think I used a dotted line to indicate White, but even that is hard to read as White.
« Reply #84 on: November 05, 2018, 02:32:09 PM »
Yes, some of the white wires are hard to see and they are dotted, but with all the "W's" on the lines it's no problem. They sure did use a completely different scheme than the English cars did!
$6.50 to print and laminate inc tax
« Last Edit: November 05, 2018, 02:35:09 PM by MiniDave »
Offline Willie_B
  • CREW
  • 1275cc
  • Total likes: 88
    • Lilburn, GA,
« Reply #85 on: November 05, 2018, 04:35:06 PM »
Dual Dellorto carbs on the one I have.
« Reply #86 on: November 05, 2018, 05:25:42 PM »
Can you buy rebuild kits for those?
Were those factory or aftermarket?
Offline Willie_B
  • CREW
  • 1275cc
  • Total likes: 88
    • Lilburn, GA,
« Reply #87 on: November 05, 2018, 05:32:20 PM »
No idea on either question. That was on it when I got it.
« Reply #88 on: November 05, 2018, 08:32:39 PM »
Engine is out of the subframe and mounted in the engine stand, tomorrow I'll start trying to see if it will run....I'm betting it will! Hardy Spicer joints are a PITA......
Added a bunch of suspension parts, bushings and such to the ever growing parts list.
« Last Edit: November 05, 2018, 08:37:42 PM by MiniDave »
Offline Willie_B
  • CREW
  • 1275cc
  • Total likes: 88
    • Lilburn, GA,
« Reply #89 on: November 06, 2018, 11:58:07 AM »
They look like there factory as the install looks too finished.
Rebuild kits are available.
https://www.ebay.com/i/230353259131?chn=ps
« Reply #90 on: November 06, 2018, 01:47:41 PM »
Not bad for the rebuild kits, I've seen SU HIf kits for way more.....
« Reply #91 on: November 06, 2018, 07:34:02 PM »
Progress, but slow......as always.  ;D
I got the intake and exhaust installed - I had to clean and rethread not just the holes but also the studs that mount the intake.
The starter from the Inno is fubar, the bushings are worn out so it won't crank under compression, but digging around in my old parts I found another starter that seems to be useable, so I mounted it up.
I had trouble geting the distributor back in and had to remove the old bracket and clean it and the end that fits into the drive gear.
i also had to convrt over to the standard oil pressure pipe as there was no room to mount the oil cooler in the engine stand - took me over an hour to find where I had put the damn pipe.
Now about all that's left is to wire it up and and get the fuel to the carb, then see if it will crank over on this starter. I'm going to run compression first too. I had to mount my spare alternator too as the Inno is wired differently.
« Reply #92 on: November 07, 2018, 02:07:56 PM »
No joy getting it to run this am....no fire, so I have to do some more sleuthing. Ran compression tho...150, 150, 140 , 145 and that's without adjusting the valves, could be more there after I get it started and blow out the cobwebs. The old starter that I dug out of my old parts stash cranks it over pretty good.
More as it happens - or doesn't! ::) 8.gif
Online 94touring
« Reply #93 on: November 07, 2018, 02:26:12 PM »
Spark, fuel, compression...should vroom vroom.
Offline velopackrat
« Reply #94 on: November 07, 2018, 03:58:56 PM »
It's fun to read along and watch the progress you guys are making.  Thanks for sharing the saga.
« Reply #95 on: November 10, 2018, 04:29:40 PM »
Spent the day tearing down the front subframe and all it's components so I can send them all off to the powder/blaster/coaters on Tuesday. Looks like it's had recent upper control arm bearings and shafts, everything else was totally knackered....all the rubbers were done, all soft and squishy from the oil and the inner sleeves welded with rust onto their shafts. The cones were about 1/2 normal size. It will all come back looking brandy new and I'll have all new bushings and bolts to re-assemble it all. Nice that it came with Hilos too......
I don't know if I can get the rear out and torn down in time to send it off with the others by Tuesday, due to the cold I can only work so long in the shop before I have to go back in and warm up again.
Subframe looks like new other than being coated in grease and grime, no damage or rust on it.
Online 94touring
« Reply #96 on: November 11, 2018, 09:00:44 AM »
Cones were a good idea to add to the list!
« Reply #97 on: November 11, 2018, 09:39:02 AM »
I also tore down the hubs, brakes and axles, I added new ball joints to the list but I think the discs are OK. I already had caliper rebuild kits in the cart so I think I'm ready to push the go button on the order today. If MiniSpares holds true to form they'll have the stuff to me no later than Thurs!
While everything is out being cleaned, blasted, painted or coated I have a lot of cleanup to do too...I plan to just take solvent and 409 to the firewall, then I have to clean everything that attaches to the parts I sent out - that will take a few days (weeks?) too.
What do you guys think for the calipers, black, silver, red.....something else? I'm thinking silver myself, since everything else in the front end will be shiny black and the car is already red.
« Last Edit: November 11, 2018, 09:42:28 AM by MiniDave »
Offline Willie_B
  • CREW
  • 1275cc
  • Total likes: 88
    • Lilburn, GA,
« Reply #98 on: November 11, 2018, 11:06:04 AM »
I did my calipers in silver. Looks good.
Online 94touring
« Reply #99 on: November 11, 2018, 02:25:58 PM »
I'd say silver or that stock gold color, but probably silver.
