Tire width for 4.5" Cooper S wheels
Started by Shrimps, July 31, 2018, 09:21:56 PM
Shrimps
What is the correct, or recommended, tire size for 4.5x10 Cooper S wheels?  I'm debating between 145/80/10 and 165/70/10?  The 145 tire width seems to be more for the 3.5" wide wheels but listings say they'll fit up to a 5" wide wheel.  This is on a '79 with 7.5" discs in the front and spacered drums in the rear.
I'm wanting to run the Cooper S rims as my daily drivers hoping the wheel/tire combo will not stick out much (if at all) beyond the original body lines (without flares).  So I'm a bit worried a 165 width may be too fat on a 4.5" wide wheel and either look funny and/or stick out more than I'd like.
I currently have 5x10 Mambas and they stick out a ton (which I knew going in) but I don't like the look as much as I hoped and the 165/70 A032 tires constantly pick up stuff from the road.  I'll save them for autocrossing.
Thanks all.
The 145/80/10 tires were the factory size (for radials) for that rim.  (Bias ply tires had a slightly different measuring system and were something like 5.20-10.)
I've had 165/70/10 tires on 5" wheels, both steel and alloy.  They fit great.  I haven't tried that size on 4.5" wheels, but I think they would work.
