Ebay Alloy Radiators - opinions
Started by Turbodave, March 14, 2018, 12:08:12 PM
Turbodave
As this looks like my new favourite US based mini forum, I figured I'd also link to this post on TurboMinis
Screw minimania. I hope everyone quits it, and that scooterboy gets to replace Jemal as the expert over there.
Lots of pics, so if you're still using your AOL CD / placemat to access the interwebs, it may take a few minutes  4.gif
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=612638
Not tried the rad out yet, but thought I'd throw it up here as it'll be in direct replacement of the minispares "super-2 core" that just isn't working out for me any more.
Many of us have used these Chinese ebay rads with great success.  Every car I do, including my own, gets one.
Welcome to the forum.  77.gif.   Scooterboy free since 2009.
Turbodave
Quote from: 94touring on March 14, 2018, 12:13:12 PM
Yes, but have you been "shirtless exposing my nipples" free since 2009?
That seems to be the most important question.
Nipple exposure free since early 2000s.  I never go on MM but sounds like it's good I don't.
I replaced a 2 core with one of these and it works brilliantly, for the money I think they are a terrific buy. I've done three of them in my cars and a friends car, none of us has had a problem with them.....
Turbodave
Did you guys that upgraded to these have issues with the two-core cooling, such that the difference was obvious first time out with the alloy unit?
Yes I went from more than 3/4 up the gauge on a really hot day (90+) to just under half - perfect!
My old worn out 998 and probably original radiator would continually run hot to the point of having to pull over on a hot midwest day. Put in the alloy radiator and problem solved. There are several ones to choose from online, from thin to thick.  I went with the thickest possible.  I want to say it was nearly 50% more capacity.
Turbodave
94 - that looks like it's the 50mm or maybe the 53mm version (depending how its measured).
There is a mac-daddy 70mm (2.75" core width) unit also available: https://www.ebay.com/itm/3-ROW-70mm-ALLOY-RADIATOR-MINI-COOPER-S-CLUBMAN-Leyland-1275GT-850-998-1098-1275/152421898552?hash=item237d0d9938:g:Tc8AAMXQUmFShwv6&vxp=mtr
but its three times the price!
#10
I want to say mine was advertised as 53 or 54mm.  The 70mm would require modifying the inner wing as mine barely fits as is.
Edit: just went back and looked when I bought this rad and it was advertised aa a 50mm 2 core.
Turbodave
I think I'm going to run this without the factory yellow fan, and instead put some ducting to pull air from the grill into the rad instead of from both sides of the engine (especially as my downpipe will likely glow red on a full boost hard pull).
I also tried fanless with no luck.
Turbodave
Yeah, I'm not saying fanless - just using the 800CFM Spal fan driven by my ECU.
I can control fan on temp, fan off temp, and if the temp sensor goes open circuit, then it'll default to leave the fan output on all the time.
If I ever get round to putting my electric pump on, I also have a "timer" mode option where I can turn the ignition off, and it'll 1) idle until the temp drops to a threshold with the pump and fan operating, or 2) turn engine off, but just circulate the coolant and run the fan until a target temp is reached, or turn off regardless after several mins.
great topic, the radiator in my 82 998 is due for replacement before the 2018 season.
@andyray998
joakwin
I have one of those eBay aluminum radiators on my lhd 998 car
And I daily drove that car for a year and had no over heating
Problems in AZ summer heat (110-115 deg) and I ran the standard
Yellow fan
 An alloy one at $51 with free shipping it is a lot cheaper option than a super 2 core one, maybe worth a try.
Turbodave
Quote from: 94touring on March 14, 2018, 07:48:18 PM
Added a post to the "restoration section"  ;D
