No start - No Fuel
Started by Flyinace2000, March 10, 2018, 07:47:46 PM
I left mine on and routed a line around it.
Flyinace2000
Next step is electrics and plumbing the pump under the boot. I've got an ignition hot line in the trunk for the reverse lights I'm thinking of piggy backing on. That way the inertia switch is in the boot, and just 1 wire going down below.
Flyinace2000
Finishing the story.  Mounted the pump on the frame under the tank at a 40'ish degree angle.  Removed an old mount for what looks like used to be a SU electric pump.  There was even a ignition hot light blue wire hiding under there.  At that point i had already installed the wiring to run off of the reverse lights.  So capped that off for a rainy day.  Had to redo some of the plumping in the engine bay as they were leaking.  But after that cleanup she runs good as new.  Ignition on, bzzzzzzz, starts right up.
