New drop gears for sale
Started by r20bmw, March 05, 2018, 01:53:19 PM
r20bmw
many miscellaneous parts for 1275 rod change.  New straight cut drop gears for sale along with a new lay shaft and thrust washer.  set of used spherical cut drop gears .used first motion used reverse, used lay gear, primary gear used thrust washers.  Diffy stump, housing and misc bearings washers etc.  New thermostat and heat control valve with gaskets.  Used 4 core radiator recently cleaned.  heater box without core.  cv joints.  miscellaneous thrust washers, primary thrust backing rings idler gear thrust washers.  used bell housings for 900 cc.  please contact me with offers for all or part of inventory.
thanks Butch
