Just ordered a Moke shell
Just picked a scrap hydro subframe today. Need to remove all the stuff on it to make it light enough to move, then clean it up and test fit. it. It is too far gone with rust to use but should work for a test fit. Cost nothing but the time to go get it. Anybody need any rear hydro stuff?
Red Riley
Quote from: Willie_B on August 29, 2020, 04:55:20 PM
Hang on to the hydro stuff. Somebody will want it eventually, especially if you throw it out. I know this.
The NEW sub fits perfect. Now to make some shims for the rear of the front sub that does not fit tight to the shell.
That solves that.  Do you know who made the other subframe?
Quote from: 94touring on September 02, 2020, 10:26:06 AM
No idea.
Also the new mowog sub is made with thinner metal than the aftermarket one. 1.2mm vs 1.5mm.
That's great news! I'm sure I'm not the only one who was a little worried that perhaps there was a problem with the Moke shell. Turns out it's perfect.
pbraun
Interesting.  I got one from Mintek and it was fine!
Peter
65 Moke
60 Bugeye modified
66 Jaguar XJ13 ( I can wish )
If you don't have a use for that bad rear frame, I could use it for my rear engine project - I'll just be cutting it up into pieces anyway so being off square won't be a problem.
Quote from: MiniDave on September 08, 2020, 06:44:20 AM
I have a couple you can have. Come get them!
Just visited the body shop and he said to he should have room for the moke next Friday the 9th. He has been very busy lately.
Shop has been doing paint jobs for a guy that is building first gen Broncos from new shells and modern mechanicals. Guy said he has orders for 30 so far.
Wow, just when I think the economy is about to tank, I read something like this! 30 "new" Bronco orders???
Can't wait to see the Moke get color at last!
Looks like the place that does the Broncos is only 25 minutes from home.
https://www.facebook.com/VintageBroncos/
According to their website inventory, 89k to 149k.  There are 2020 Broncos listed there for 199k.
Quote from: Willie_B on October 02, 2020, 11:41:23 AM
Why don't they just list the 2020 Broncos for a gazillion trillion billion dollars?
Quote from: BruceK on October 02, 2020, 12:07:25 PM
So before the shell goes to paint I have been going over photos to make sure if I need to drill any more holes or anything else. Did find a couple of holes to add but also saw a welded on nut that was needed. Not able or willing to weld a nut on at this stage, more so as it is on the passenger side of the firewall for all to see.
Time to get creative yet again. Can you put a nutsert inside a nut???  Yes with a little work. Find the right size nut. Trim the nutsert down to the length needed. Drill out the inside of the nut so it will fit over the nutsert, then counterbore the inside a tiny bit so it will fit over the crimp part. A bit of JBWeld to hold the nut on and should be good to go. As the nut is just a cover for the nutsert glueing it on should work ok. It will be painted over when the shell gets done.
The last photo shows where I save the little plastic parts that bits come in to mix things like epoxy or JBWeld in to keep it contained.
Speaking of Mokes, I ordered a steel Moke seat today for Clancy's Moke, $310 plus shipping for one bare, steel seat! Crikeys!  :-\
Original UK Moke steel seats have been known to go for as much as $1000 each!  Talk about crazy.
Off to the body shop for paint. Bout time.
#173
Another part for the moke is close to being done. I got a new commission number plate but they do not come with the red printed info on them. Asked a friend that does screen printing if he could do it. Just got this photo of it. Now I need to send it off for the stamping part to be added.
No idea how to change the file type so it just shows up without having to download it.
