Author Topic: hello new to site, vtec automatic swap  (Read 63127 times)
Online MiniDave
Re: hello new to site, vtec automatic swap
« Reply #400 on: July 06, 2019, 06:13:21 PM »
Wow, I didn't think you guy's monsoon season was till August?
I wondered if they used wood this time!
Offline joakwin
« Reply #401 on: July 06, 2019, 09:24:07 PM »
the last one was shipped with ups and the box was bent in the middle, so wood to make sure the box dont get beat up in shipping and bend the window seals
monsoon season starts June 15 and ends Sept 30th, but the weather has been weird, its raining at other places around us but seems to kind of go around my street and skip us
I can smell the rain in the air but nothing yet
Offline joakwin
« Reply #402 on: July 08, 2019, 11:05:27 AM »
this morning I started to build a 8x7 shed in the back yard, its going to hold the bicycles and extra mini parts to get them out of the garage to give me more space
so far I built the base of the shed out of 4x4, took alittle more then 5 8ft sticks for the base, I plan to cover that with some 3/8's ply wood, so far I have 1 hour into build time
I had to pick up more air line to run line from my garage compressor to the back corner of the back yard, so far 100ft, but ones I start working on the roof, I may need another line
I picked up a wall locker for the garage for more space, to hold parts and tools
im trying to make room for a 20 ton shop press, I want one with a air bottle jack when will start out with a regular bottle jack
Online MiniDave
« Reply #403 on: July 08, 2019, 12:23:42 PM »
Best thing I did was to build a shed in the back yard for the mower, genset and all the gardening stuff. I'll bet 8X7 won't be nearly big enough for you!  ;D
Shop press is a very handy thing to have, you don't need it often, but when you do - it's not one of those things you can borrow easily from a buddy.
Offline joakwin
« Reply #404 on: July 08, 2019, 05:55:25 PM »
8x7 probably wont be but its a start
Offline joakwin
« Reply #405 on: July 08, 2019, 05:57:08 PM »
worked on this this afternoon to finish it up and get it sitting on the tires
s-10 blazer 2 inch drop spindle, dehumped lca, flat plate upper arms, home made caliper bracket, z06 calipers,
home made air bag brackets, SS-7 air bag
« Last Edit: July 08, 2019, 06:00:13 PM by joakwin »
Offline joakwin
« Reply #406 on: July 12, 2019, 02:21:59 PM »
first fill going on right now
Online MiniDave
« Reply #407 on: July 12, 2019, 02:56:42 PM »
How long will that take? A couple of days?
Offline joakwin
« Reply #408 on: July 12, 2019, 03:44:13 PM »
i'll be done later tonight
Offline joakwin
« Reply #409 on: July 13, 2019, 02:09:15 PM »
19 hrs to fill the pool
Online MiniDave
« Reply #410 on: July 13, 2019, 07:29:12 PM »
Offline gr8kornholio
« Reply #411 on: July 13, 2019, 09:10:30 PM »
How’s the evaporation rate out there?
Offline MPlayle
« Reply #412 on: July 13, 2019, 11:53:06 PM »
A solar cover will help reduce the evaporation factor a bunch.  It is like a bubble-wrap product that floats on the water.  You cover the pool when not in use and it reduces the evaporation as well as the chemical burn off.
« Reply #413 on: July 14, 2019, 08:07:37 PM »
Yea friends pool had that growing up. Down side was one day with the cover on and the water temp would be north of 80.
Offline joakwin
« Reply #414 on: July 14, 2019, 09:18:41 PM »
yeha i plan on getting the cover for the pool, I want to build the rack set up myself...….
im going to need another die for my tube bender, lol
im thinking 1.5 inch tube in the middle, and then a 1 inch tube wheel to roll it up and whatnot,
probably going to build it in a few weeks
Offline joakwin
« Reply #415 on: July 14, 2019, 09:24:51 PM »
new tool, im loving it so far, super nice circle with this tool
first time using this
Offline joakwin
« Reply #416 on: July 16, 2019, 02:22:23 PM »
https://youtu.be/4rsfg2fp5Ug
playing around with a single 4ohm svc cv stroker powered by a Mackie fr 1400i, 1400watts@4ohms mono
Offline joakwin
« Reply #417 on: July 22, 2019, 07:18:13 PM »
brand new mk2 tail lights from mini sport, just came in
I plan to paint the chrome parts satin black
Offline joakwin
« Reply #418 on: July 26, 2019, 10:10:08 AM »
painted the tail light housings satin black
the gas cap cover fell off from the base, im thinking about trying to jb weld it back on and order a new cap
Offline joakwin
« Reply #419 on: July 26, 2019, 05:19:34 PM »
this morning it was a cool 97 degs, so i removed the heater core out of the shell and stuck it in the engine bay, im going to put small fans on it,
so that it can act as another radiator, because being real about it, im never going to drive the car when its cold out
and I finally installed the led headlights, I haven't turned them on yet but they are installed
im thinking about making a custom grill, vs using the stock clubby grill
Online MiniDave
« Reply #420 on: July 26, 2019, 07:08:52 PM »
The regular Honda radiator isn't sufficient? They seem to do OK in a Honda....
Offline joakwin
« Reply #421 on: July 27, 2019, 04:08:10 PM »
the alloy is nicer and its also double the thickness of the stock radiator
and its a hair wider, so I was able to put a bigger e fan on it
Offline joakwin
« Reply #422 on: July 27, 2019, 06:11:21 PM »
led hi beams and led spot lights on
Offline joakwin
« Reply #423 on: August 02, 2019, 07:32:06 PM »
today i cut the lower lip off the front clip, it was to low and i jacked it up on the driveway
i need to work on fitting that rubber trim part alittle better, but i ended up painting the lower half of the front clip
and repainted the hood
and painted the rocker panel area of the car od green
and worked on the trans cooler trim and grill
i picked up more allen head bolts for it
and will need to paint them
Online MiniDave
« Reply #424 on: August 02, 2019, 08:23:46 PM »
Looks very purposeful.....are you driving it much yet?
