joakwin
Quote from: MiniDave on November 04, 2018, 07:35:07 AM
Can you do a vid? I'd love to hear what it sounds like with that exhaust......
yeah I will
getting my coffee in right now before any thing can happen
joakwin
video-1536969967 by joa kwin, on Flickr
here's the side exit with the bigger pipe
click on the picture
1st drive by joa kwin, on Flickr
here's the bigger pipe with the exhaust out the back
joakwin
I got the twin box rc40 mounted to the car and so far I think its what ive been searching for as far as exhaust sounds go
I still need to test drive the car to see how it sounds with higher rpm,
but I can tell that it doesn't sound as loud and I think it sounds pretty deep and
I feel it doesn't sound all ricer
twin box rc40 exhaust video by joa kwin, on Flickr
click on the picture and it will take you to where the video is
joakwin
#303
I think my cooling problem is a stuck thermostat
or the new water pump is bad
im thinking thermostat is bad, because the lower hose is hotter then the upper hose
edit, I tested the t stat and its good
tomorrow I plan on back flushing the engine, but I think thats fine
I did a compression check and everything was at 175-180, pretty even on all 4 cylinders, so I think my head gasket is good still
I do plan to get my alloy 2 core radiator fixed and I plan to modify a stock R53 e-fan to fit behind the rad
with the two of them next to each other, they are about 4.5 inches deep, and the fan housing design gives me good space for the upper hose to connect to the rad
so its just a matter of cutting up the fan housing to make work with the honda rad,
tomorrow I will see if this is do able or not
my R53 e-fan relay is bad, but I plan on cutting that of and just running the two wire set up,
I know the fan works because when it went out on me before, as a temp, I jumped the relay on the houseing and made that mug work so that I could go buy a replacement fan
ps....oh yeah I almost forgot to say anything about the exhaust, I took the mini up to 90mph, or what my speedo says anyways, I think it was more like 75-80mph
and the exhaust is loud but it is a livable loud, I dont think its over the top loud, just perfect for the amount of volume it puts out
and driving it around town doing anywhere from 30-45 mph, it was nice and I even had the side pop out windows open
I think im going to be happy with the exhaust this time around, or happy for now
edit one more time......I just looked it up, tire size comparison, at 90mph on the speed, the mini is doing 82.5mph, it did that speed with no problems, and it felt like it had a lot more to give,
#304
What RPM were you turning at "90" mph? I would have thought the automatic would have a taller final drive ratio. I recently put a taller diff in Don's Pup, went from a 4.27 to a 3.75, really made the car a lot more livable.....
I thought that exhaust sounded pretty good, not too "Honda-ish"   ;D
Overheating....are you sure the rad is clean and flowing freely? I always check the easy stuff first. The R53 had a two speed fan, usually what fails is the resistor that controls the low speed....the fan is fine but they didn't sell the resistor as a separate part - now they have a kit to replace just the resistor, so if you get one of those you can have a two speed fan again.
You're getting there!
joakwin
The r53 fan didn't work out, I stuck a Chevy impala cop car fan into the mix
I back flush the engine today, I put a blank t stat and the engine seemed to stay cooler for a lot longer now
After running the engine for a hour the engine temp was half way
But I noticed that when I rev the engine up, alittle bit of water comes out of the exhaust
And after about 2 hours of running, I noticed that high revs it would smoke white alittle bit
That would be signs of a cracked head on the exhaust side of it
I ran a compression test and those numbers where great ie 175 range
So I think I'm going to have to buy one of those kits that can tell me if their is compression going into the coolant
Water coming out of the exhaust is a normal byproduct of combustion, white smoke may or may not indicate a problem. Usually if combustion gasses are leaking into the cooling system you'll see bubbles in the radiator....
joakwin
Quote from: MiniDave on November 07, 2018, 02:01:56 PM
yeah it has some of those as well
the del sol always had a over heating issue from when I got it at that auction summer of 2017, but my winning bid price for it was $275
not to bad of a price,
theirs a place up in phx that i can get a rebuilt motor for $950 with no core, and they come with a 75.5mm bore
that should make alittle more power
so maybe next year or so i'll buy another d16 motor
but for now, i plan on trying to find another used head for this motor and go swap it out in the next few weeks
but today i put a bigger fan onto the rad
this fan is super loud
i got it out of a chevy impala v6 car
the a/c fan motor went out, and so the twin fans were replaced, so i took the set up to cut it up to fit the main cooling fan on the mini
joakwin
joakwin
speaker pods by joa kwin, on Flickr
made some sealed speaker boxes for some jbl 6.5 2 way comps
Those look nice, where are you mounting them?
joakwin
speaker pod location by joa kwin, on Flickr
this was before I cut the pods down to make them smaller
i had to cut them down a hair to clear the throttle pedal on the other side
joakwin
black carpet speaker pods by joa kwin, on Flickr
I ended up cutting down the speaker pod alittle bit, its not as big so I hope that it doesn't jack up the sound from them
or well, I can always build more
tomorrow I plan to get this box mounted to the car
if I can get over my man flu I got going on right now
today was pretty bad, all of my joints hurt like crazy, everything felt cold, aka the man flu
It's going around...I have it too, as do a few of my friends....
joakwin
Quote from: MiniDave on November 14, 2018, 10:29:40 PM
looks like the other day was the worst, and it seemed to break last night, I was able to sleep all night
today my joints dont feel cold, after morning coffee its time to get to work
going to get the 2nd speaker covered and mount the pair
joakwin
joakwin
joakwin
#318
jbl in the house by joa kwin, on Flickr
lost the gun trigger from my lincoln welder, but found a new one in town for $3.28
i made a metal frame to hold the amp, i still need to build one more bracket for it
tomorrow i plan on running power cables and speaker cables,
the stereo is pre-wired but i havn't installed the stereo into its home yet
the speaker boxes and amp dont get in the way of leg room on that side
joakwin
#319
got the stereo and amp working together today
for some reason I wasn't getting a ground in the harness that I had hooked up for the stereo,
alittle bit of troubleshooting and I ended up using a ground off of the a/c control wiring
stereo works,
the speaker pods gave those speakers a lot of mid base, I had to eq the mid bass down, but it still has good punch to it
I was playing some of the mix from Dj Rectangle, ill rated, I like to test it all out before getting the deck put into its house
JBL gto 6.5 comp 2 ways 2ohm speakers, jbl amp that puts out 80x2@2ohms, speaker pods are made out of 3/4 mdf, I didn't use any poly fill in the boxes
kenwood deck that I forget the model, but I have the speakers crossed over at 120hz,
im still working on getting the sub amp installed, only place I have room for it right now is on the right side of the boot
and I have two mtx thunder 5000 8's, that i plan to push with 300watts for now, i plan on buying some micro amps down the road,
the mono micro amp im looking at puts out 470watts, should be nice for those two 8's
the other pair of 8's i have are some sony's, they are in a small sealed box, i plan to test the sony's and the mtx's to see what sounds the best to me
and for now will stick them on the back seat until i build a box for the rear deck
joakwin
new box by joa kwin, on Flickr
I built a new sub box for the daily ride
joakwin
old box by joa kwin, on Flickr
old box and new box as im switching it out
joakwin
sub box by joa kwin, on Flickr
in the process of building a box to hold two 8 inch subs, it looks ruff but its far from done
joakwin
joakwin
