Author Topic: hello new to site, vtec automatic swap  (Read 55004 times)
Offline joakwin
Re: hello new to site, vtec automatic swap
« Reply #425 on: August 03, 2019, 12:04:58 AM »
not a lot, I still need to do a few small things
mostly I drive it to pick the kids up from school, like 1-2 times a week
just day time driving it around because I dont even have the front turn signals installed right now
and I dont have a plate light on it right now, in the day time thats fine but night time, cops wont be happy with that
but I got some slim low pro lights to use for the plate, im going to install those tomorrow morning
and I dont have the wiper arms on it, not that I really need them
turn signals for the front will go in tomorrow morning as well, I have everything, its just a matter of doing it between other projects and the rain
Offline joakwin
« Reply #426 on: August 03, 2019, 12:12:57 AM »
I pulled the stock honda air bag steering wheel, and im changing out the stock del sol upper dash switches
the haz switch is now one from a 2000 civic,
the aux light switch is a led light switch
and the cruise main power switch is now one from a 2004 civic
this is the stock del slow cruise and aux light switch, ugly and huge
the 2004 civic cruise and the 2000 civic haz switch
the cruise switch was a straight up swap, same wire colors different plug size
the haz took alittle work, went from a 5 wire haz switch to the 2k civic having 8 wires
a red and a red/black wires from the switch went together to the red or red/black wire on the del sol side
and a green/white on the switch went to a green/orange on the switch
and the rest of the wires were simple, turn left/right wires and power and ground and ign
Offline joakwin
« Reply #427 on: August 03, 2019, 12:16:41 AM »
the adapter is a nrg, im not super happy with it, it doesn't have anything for the horn wiring to connect to the back side, so I have to rig something up or move the horn switch
but I like the horn in the center of the steering wheel,
I have this nice suede nrg steering wheel, I like the flat spot on the bottom, it helps to get my legs into the car and whatnot
Offline joakwin
« Reply #428 on: August 03, 2019, 12:22:50 AM »
2000 civic haz switch, super simple to wire
just have to figure out how and where to mount it
and build a dash would be nice
not having a dash gives it a huge project look, lol
Offline joakwin
« Reply #429 on: August 03, 2019, 12:32:14 AM »
with the 4 lights on, I think its with the hi-beams as well
4-led lights
« Reply #430 on: August 03, 2019, 07:36:47 AM »
The bounce back reflection of the square lights is interesting!
So many little details to do, I guess that's what keeps us off the streets and out of the bars, huh?   77.gif
Offline joakwin
« Reply #431 on: August 03, 2019, 11:32:41 AM »
I love it tho, working on projects and learning stuff and getting better at jobs to take the build to the next level, small details
Working on the car is fun to me
Offline joakwin
« Reply #432 on: August 04, 2019, 12:57:59 PM »
wired up the plate lights last night
super simple, two single lights with a single led in each one
im working on back up lights and rear fog,
im going to be use some stock Harley parts for those
I have to run full wiring for the fog light, plan to use a led switch
and the back up wiring is done already, stock honda green/black wire
and then im looking into wiring a 3rd brake light, but I have to look up the wiring colors for it and figure out where I tapped off the stock honda wiring for that
the harness is stock, I haven't cut any plugs off of it, just tape them off if I didn't need them
didn't want to cut something and then have to add it back in later, plus then I can t/s the wiring like a stock eg civic or del slow
Offline joakwin
« Reply #433 on: August 04, 2019, 08:17:51 PM »
working on rear fog light and 3rd brake light, and back up light
rain came so that work got cut short today
but I ran the wire for the fog light inside the shell already
and figured out where the wiring is for the 3rd brake light
this is going to be the back up light
Offline joakwin
« Reply #434 on: August 04, 2019, 08:21:28 PM »
light is kind of tucked under the car
Offline joakwin
« Reply #435 on: August 06, 2019, 10:21:56 AM »
single back up light hooked up
had to do alittle adjusting of the shifter to get the electric switch to line up
but it works now
Offline joakwin
« Reply #436 on: August 07, 2019, 11:27:35 PM »
https://ibb.co/N1CJmPM
working on installing the quick disconnect for the steering wheel
« Reply #437 on: August 08, 2019, 09:24:29 AM »
My 09 Clubman has only one back up light from the factory (cheap bastards) and I can't see shit behind me - does this one light throw enough back there for you to see?
My classic has two lights and I can see fine when backing it up
Offline joakwin
« Reply #438 on: August 08, 2019, 11:18:46 AM »
I haven't tried at night yet
Offline joakwin
« Reply #439 on: August 09, 2019, 10:07:22 AM »
working on the grill
bench racing with the seats and the steering wheel
Offline joakwin
« Reply #440 on: August 09, 2019, 05:28:37 PM »
« Reply #441 on: August 09, 2019, 06:54:06 PM »
What seats are those? They look way comfy!
Offline joakwin
« Reply #442 on: August 09, 2019, 09:51:27 PM »
ebay seats, they are kind of big but they feel great
without the roll cage, the install would have been so much better
only thing I dont like about them is the slider adjustment handle, it keeps popping off but the way I set it up, I dont care if the seat dont adjust
im going to do the same for the drivers side, set it for me and thats it, no one else will ever drive my mini, so I dont care, as long as im good with the seat spot
« Reply #443 on: August 09, 2019, 10:30:57 PM »
Is there a link? What did they cost?
Offline joakwin
« Reply #444 on: August 10, 2019, 12:14:22 AM »
https://www.ebay.com/itm/FULL-RECLINABLE-PVC-CARBON-STYLE-LEATHER-RACING-SEATS-ADJUSTABLE-SLIDERS-RAILS-/401510535236?txnId=777625340027
$228 bucks shipped
I dont know how long the vinyl will last but I dont drive the car a lot
My other classic buckets were vinyl
So Im sure it will be fine for the most part
I wonder if I could mod the del slow sliders to work on these seats.....hummm
I got these seats back at the beg of May, they have been sitting for a long time
Most of the parts I have for the mini have been sitting,
The led headlights where a Christmas gift
Im thinking of going back to classic mini seat belts, ordering some new ones in black color
Will probably order them from mini sport USA
7 has them for 75$ each
« Reply #445 on: August 10, 2019, 09:16:09 AM »
I bought a set of seatbelts from MiniSport - they're in my Racing Green car - and they're OK, but the set I bought from MIniSpares to put in the Innocenti  seem better - the nylon webbing was slightly thicker and they felt higher quality. Both were similar prices, but I think the Spares ones were just a bit cheaper.
How do those seats feel? I'm always on the lookout for some good seats for Minis, as the originals are pretty awful. I put Miata seats in my Clubman Estate and they were pretty good, I had to make brackets of course, but they fit well and I could slide them all the way back to the front edge of the back seat, plus they sat lower.....
Offline joakwin
« Reply #446 on: August 10, 2019, 02:51:19 PM »
I hated the stock seats
and then I found someone selling some classic bucket seats with head rests, I picked them up for $50, at the time I fit into the seats fine, I was a lot smaller and weighed less......these seats https://usa.minisport.com/cobsfx051-black-vinyl-with-head-rest.html
now I can only use those seats for short distance, im a lot bigger now, 6ft 210lbs, and the hip area is to small for me
so my kids use them as gaming chairs
and then I went to some K11 Nissan Micra seats, those were super comfy, a lot of padding on the bottom and back, I used to drive from
RAF Mildenhall in England to Spangdahlem AFB in Germany in a Nissan Micra, all the time, and thats why I love those seats, my butt never hurt from the drive
but on the rebuild of my car this time around, I put the stock del slow seats into the mini because they are skinnier
but I didn't want to pay to get them recovered and some of the foam was messed up from getting in and out of the car
so I found these new seats last May on ebay
they have a good amount of padding and feel comfy and the hip area is wider, and has good size lats support,
so I can see myself doing road trips in them
I think I set the front of the seat around 3-4 inches off the floor and the rear around 1 inch or so, so the sliders can move is need be
and lean the top back
the only problem I see so far is the bar for the adjustment keeps coming off, and the top dont lean forward much, so if you bolt the rear of the seat to the floor, you probably wont be able to fit people into the back seat area
im fine with that, because im not going to put the back seat into my car, im going to move my stereo amps into the back seat area
my driver's seat is so far back, that its pointless to have a seat in the back because it has no leg room
also it helps to move the passenger weight as far back into the car
im still looking for seat belts,
I started to look at summit racing
I have some 4 point belts from them, but I dont want to daily drive or cruise with 4 point harness seat belts on
Offline joakwin
« Reply #447 on: August 10, 2019, 03:19:28 PM »
no lights other then the back up lamp with engine off
running lights with back up lamp with engine off
head lights on with back up lamp, at 12v, key on engine off
its a single 1157 bulb with the two sides wired together
I found a nos copy of this, still sealed
« Last Edit: August 10, 2019, 03:35:23 PM by joakwin »
« Reply #448 on: August 10, 2019, 03:38:57 PM »
Yeah, those MiniSport style seats are made for people with the hips of a 13 year old boy! Miserable for any real sized adults....
Offline joakwin
« Reply #449 on: August 10, 2019, 03:42:31 PM »
i painted the mirror green to see how it looked but i think black is going to be better
it was bed lined black and then painted pd green and now its black again
I put it on the car with it being green but I forgot to take a picture
so this morning I painted it black again
and because its raining its tail off, its taking alittle more time to dry
but its been going off for about 2 hours now
not working on the mini today
last night I was getting ready to paint the other side, tapping off the glass and I dropped it like a I was so mad at myself
but I found a guy selling a pair on cragslist here, from a sportster, so it should be the same
