Author Topic: Can you help solve this mystery?  (Read 603 times)
Offline SantaFeMike
  • Active members
  • Total likes: 0
    • Santa Fe, New Mexico, US
« on: August 15, 2017, 01:31:08 PM »
1971 Mini Cooper S starts and warms up, runs down the road a bit, then conks out as if it's out of fuel, but new fuel pump is getting gas to the engine.
What might be causing this?
What might be a possible solution?
What questions do you have.
I am Sleepless in Santa Fe.
Re: Can you help solve this mystery?
« Reply #1 on: August 15, 2017, 01:43:05 PM »
Clogged filter?  Float bowl stuck?  Mechanical or electric fuel pump?
« Reply #2 on: August 15, 2017, 01:44:06 PM »
When it conks out, is it sudden, like someone threw a switch or gradual, like it's running out of gas?
Offline Willie_B
  • CREW
  • 1380cc
  • Total likes: 38
    • Lilburn, GA,
« Reply #3 on: August 15, 2017, 01:47:46 PM »
Fuel tank not vented.
Offline SantaFeMike
  • Active members
  • Total likes: 0
« Reply #4 on: August 15, 2017, 01:51:49 PM »
Fuel pump is mechanical.
Offline LarryLebel
« Reply #5 on: August 15, 2017, 02:07:58 PM »
Blocked fuel line (s) or pipes on the float bowl(s).
Offline Bahowe1
« Reply #6 on: August 15, 2017, 04:12:09 PM »
Will it start back up after dying? easily?
Do you know fuel pump is supplying enough (i.e. More than just start and idle)?
Offline jedduh01
« Reply #7 on: August 16, 2017, 07:35:53 AM »
Float needles sticking closed. Not letting enough fuel to re fill the fuel bowls.
After a LIGHT needle sanding on the edges to free up the needle problem solved.  )this could be exasperated by ethanol fuel - purely a theory.)
Offline DS1980
« Reply #8 on: September 25, 2017, 07:02:19 PM »
Don't know if this has been solved, but mine was doing this and it was the points condenser.
