Author Topic: Moke project extras for sale  (Read 505 times)
« on: June 12, 2017, 08:57:02 PM »
Some of the "extras" from the Moke project that are now going up for sale:
(All prices are "or best reasonable offer" and do not include shipping costs from 78240.)
1 - DAM2886 cased A+ rod change & pot joint transmission (used, includes input shaft bearing and idler gear and bearing for A+ serviceable 'as-is', no pot joints) - asking $300
1 - CAM4810 casting 998 cylinder head (with springs & valves - no rockers) - asking $150
1 - 3.1 final drive set (used? - came with purchase of the Moke) - asking $80
1 - 998 factory intake/exhaust manifold for HS-4 carb (used, includes "pre-heat" housing for factory air box) - asking $40
1 - HS-4 carb for rebuild (used) - asking $100
« Last Edit: October 31, 2017, 05:11:47 PM by MPlayle »
Re: Moke project extras for sale
« Reply #1 on: October 19, 2017, 08:41:32 PM »
Updated the list above: the old engine is being sold and the spare 998 manifold and rebuildable carb are going with it.
Prices also updated.
Offline SomethingNew71
  • 998cc
  • Total likes: 2
  • Everything will be alright in the end.
    • Piedmont Classic Minis United
« Reply #2 on: October 23, 2017, 08:01:48 AM »
Hi is the rod change system still for sale? If it is would you be willing to ship it to NC?
« Reply #3 on: October 23, 2017, 09:29:10 AM »
Yes, the rod change transmission is still available.
Shipping is up to you, I am willing to send it wherever you make arrangements for it to go.  I will get it boxed up and try to get an approximate weight for getting shipping quotes.
Edit: PM sent.
« Last Edit: October 23, 2017, 05:48:18 PM by MPlayle »
Offline kcmini
« Reply #4 on: October 23, 2017, 06:10:33 PM »
which transmission did the 3.1 final drive come out of  thanks  Kerry
« Reply #5 on: October 23, 2017, 06:16:44 PM »
Kerry,
The 3.1 final drive was not in any of the transmissions I have.  The person I bought the Moke from had it as spare and provided it along with the Moke as I was considering upgrading the original transmission to the 3.1 final drive.
From what I had read, it should fit any Mini transmission.
« Reply #6 on: October 23, 2017, 06:36:23 PM »
It should, the only thing you may have to do to use it is ream the retainer bracket slightly to clear the larger pinion gear.
« Reply #7 on: October 31, 2017, 05:13:43 PM »
Offer accepted on the transmission.
Original post updated.
There may be some other stuff pop up as I finish going through things removed from the old shell refurbishing to go onto the new shell.
« Reply #8 on: November 04, 2017, 12:30:50 PM »
The old Moke shell and rear subframe are going to Hugh Cannon.
There will likely be a few other bits added to the list in the coming few weeks.
