64 Mk1 Engine problems
Started by Armycook, April 03, 2017, 08:25:04 AM
While we're on the topic, here are timing curves for the csi.  As an added bonus here is an aldon yellow curve (figures need doubled) for performance reference.
So, do you know which curve you want to use?
I'll look at my notes but 10 or 11 I believe.
Good to know, that looks like a good starting point at least.
That Aldon curve looks slow to me.....but the only real way to know is to put the car on a Dyno.
Armycook
i ordered the 123 ignition and I still have a 3ohm coil at home so ill just use that. Right now i just need to make a baffle behind the block where mech fuel pump blanking plate as it's spraying oil out of the hose to the small K&N filter i installed.
Armycook
yeah i tried that. studs won't come off. i did the 2 nut method still not coming off.
A piece of sheet metal with a lot of 1/8" holes in it mounted behind the plate would do the trick.
