Upper ball joint
Started by bahoffe, July 24, 2009, 09:20:21 AM
bahoffe
Attempting to reinstall my upper ball joint and have it back in the upper A arm however the shaft of the ball joint keep turning when attempting to tighten the nut.  Is there a trick to stop this from happening?
Hayman9644
Take your jack and put it under the lower ball joint/control arm.  That forces the ball joint back into the upper arm and that holds it enough to get the nut tightened.  Let us know how it ends up.
