Author Topic: Ivy - 1995 Mini Cooper  (Read 15682 times)
Offline flipstah
Re: Ivy - 1995 Mini Cooper
« Reply #100 on: August 09, 2017, 12:42:35 PM »
Offline jeff10049
« Reply #101 on: August 09, 2017, 11:59:14 PM »
Too bad your fancy image stabilization doesn't stabilize the image.
We still see eachother. Monday was actually a holiday here, and I drove mine the entire long weekend, all 3 days straight, but there are some issues. Mostly I get a solid clunk when going over bumps. I suspect shotty engine mounts, or something front subframe related. Also anthing over 25% throttle, I get a weird rattle, almost like heatshield or coins or something. I expect it's potentially valve float.
Sounds like it could be pinging.
Check the timing.
sorry don't have time to write a description here is a decent write up http://www.misterfixit.com/deton.htm
Offline LilDrunkenSmurf
« Reply #102 on: August 10, 2017, 12:13:45 PM »
Check the timing.
I thought that might be the issue, but I'm running 91 octane, and can't adjust timing on an SPI.
Offline flipstah
« Reply #103 on: May 28, 2018, 02:44:25 PM »
Wow, I can't believe it's been this long since I did an update.
92k original kms and Ivy is still running strong. I've been toying with the fact of putting a VMax supercharger kit on it but don't know if the gearbox can handle it.
Just finished a car show this weekend and our car club won Best in Class!
« Reply #104 on: May 28, 2018, 02:56:15 PM »
6 people in a Mini!
Congrats on the win!
Offline flipstah
« Reply #105 on: May 28, 2018, 03:22:53 PM »
6 people in a Mini!
I was surprised how many wanted to sit in it. So I just left it open throughout the event and everyone loved it!
Then someone came by our booth and asked,
"How many people can fit in it?"
"I don't know. Let's find out."
Would've been better if it was me and 5 ladies c'est la vie such is life.  62.gif
My buddy who brought his Mini got attention as well because his is more stripped out and race spec with a three-piece 10x8 wheel.
Sitrep: Smurf is missing, still. :(
« Reply #106 on: May 28, 2018, 03:53:52 PM »
Yeah, where is Smurf?
Offline flipstah
« Reply #107 on: May 28, 2018, 04:05:55 PM »
« Reply #108 on: June 01, 2018, 11:19:33 AM »
I was approx 1200km away on a work contract. He never even offered to pick my car up and take it to the show for me.
Offline flipstah
« Reply #109 on: June 01, 2018, 11:47:20 AM »
I'm only one man!
« Reply #110 on: June 01, 2018, 11:55:42 AM »
Hey Smurf, glad you're back - no internet where you were?
Offline jeff10049
« Reply #111 on: June 01, 2018, 11:00:48 PM »
Smurf, Did you ever figure out the pinging noise? It is hard to change the timing on a spi but you can check it to make sure its right? clocking the dizzy correctly does have some effect so make sure that's right.
« Reply #112 on: June 03, 2018, 07:50:41 PM »
I had internet, just busy with work. I only tend to check RM while at home.
Sure didn't! Or the clunk, or the high speed wobble. I should just hurry up and do that honda swap in 10 years...
Offline flipstah
« Reply #113 on: June 05, 2018, 11:44:44 PM »
So I've been getting exhaust fumes in the cabin so might be time for an exhaust change.
Straight pipe or no? Hmmmmmm
Also time for maintenance so spark plugs, leads, oil change...
Hopefully the list you all have for compatible filters will work.
« Reply #114 on: June 06, 2018, 08:34:40 AM »
I use this stuff to seal exhaust up, works very well...
« Reply #115 on: June 06, 2018, 09:23:40 AM »
If you're in a bind, I think I might have 2 filters around, you could have one, if you replace it.
Offline flipstah
« Reply #116 on: June 08, 2018, 05:44:06 PM »
Thanks Smurf for the oil filter.
Time to do some maintenance since I only got 247km last tank.
Spark plugs/wires
Oil change
Vacuum line check
Check brakes
Fix handbrake
Check for leaks (oil and exhaust fumes)
Tire rotation
Fix AC
Gonna be busy day tomorrow!
« Last Edit: June 08, 2018, 05:46:42 PM by flipstah »
Offline flipstah
« Reply #117 on: June 09, 2018, 05:08:40 PM »
Did the annual maintenance,
Oil/spark plugs change (only 3/4 since the 4th one is a PITA to get into. Getting a tool from Japan to do it)
Tire rotation
Check for leaks and diagnosis
Throttle body cleaning
Engine cleaning
Is it suppose to spew out that much fuel? Its like a hose.
« Reply #118 on: June 09, 2018, 05:45:41 PM »
The SPI being a single injector for feeding all 4 cylinders, it would seem like a hose.
« Reply #119 on: June 09, 2018, 06:23:44 PM »
How is the spark plug hidden? Is it behind an A.C compressor or something? What sort of special tool do they sell to change it?
got a link or a pic?
On Sunbeam tigers with the Ford V-8, two of the plugs you got to from under the wheel well, the back two you had to remove a large panel under the pedals!
Offline flipstah
« Reply #120 on: June 09, 2018, 06:31:59 PM »
Dave, it looks like pliers. I'll see if I can find a photo.
Yeah, hidden behind the compressor! That sucks about the Sunbeam but a V8 though!
Offline flipstah
« Reply #121 on: June 10, 2018, 07:23:00 AM »
Re: Dave
« Reply #122 on: June 10, 2018, 07:42:06 AM »
wow, that's interesting....is it that hard to loosen the compressor and move it out of the way enough to get a normal socket and extension on it?
Obviously no need to do that if you have this tool.....
Offline flipstah
« Reply #123 on: June 10, 2018, 08:10:29 AM »
The compressor and the alternator are stacked on top of one another so moving that + shield was cumbersome. There were AC lines that I'd have to move and I gave up.
« Reply #124 on: June 10, 2018, 08:56:20 AM »
Wow, that pic clears it up.....what a PITA for one spark plug.  ::)
