Author Topic: Introduction - '74 Mini 1000, Blue Thunder in NM  (Read 16963 times)
Offline bryanp
Re: Introduction - '74 Mini 1000, Blue Thunder in NM
« Reply #50 on: December 10, 2017, 06:50:24 PM »
ok, so I made a little more progress.  I had fabricated a plate that sits on top of the sheet metal "tray" that goes between the firewall and the partial tube section that is the front rail of the dash.  Holy cow, I can't describe what a PITA it was to get three sets of holes aligned/drilled in the plate, the tray and the top of the OBP pedal box.  Finally got it to work (God bless the Dremel) and hung the pedal box about 1.5" below the plate/tray.
I was also able to source an extended, adjustable steering column lowering bracket from Swiftune in the UK.  Unlike the gorgeous billet bracket from DSN Classics, this one angles away from the bottom of the rail, so the fouling problem I had w/ the middle master cylinder in the pedal box is now solved.
Another glitch was that my original set of holes in the plate and tray ended up placing the brake pedal in the way of the steering column by about 1/16.  With a lot of filing to get the pedal box more to the right, and skootching the bracket to the left, I now have 0.5" between the column and the brake pedal at its closest point (the column angles towards the centerline of the car).
I set the driver's seat in the car and sat in it, just to make sure all the geometries had all finally worked out.  I think I can say that the car is officially LHD . . . .   I will still be a somewhat splayed-knees driver, but that's life in a Mini.  I am feeling pretty energized now.  I will mount the 3-reservoir plinth in the engine bay and use some tubing to mock up the six lengths of stainless steel woven master cylinder hoses I need to have fabricated.  I will remove the pedal box and mount up the other two cylinders and bias bar.      Then back under the dash to work on mounting the pint-sized heater from MiniMania . . . . another transition plate in my near future.
« Reply #51 on: December 10, 2017, 06:59:42 PM »
Very cool, progress........
You mentioned fuel pressure, those webers are very sensitive to fuel pressure - 2 - 2.5psi is all they want. I like the regulator with the filter built in - who makes that?
Offline bryanp
« Reply #52 on: December 10, 2017, 07:15:31 PM »
the mfg is Malpassi Filter King.  The gauge is an add-on; you have to pick one where the filter body has been drilled/threaded for the gauge.  I'll go thru my file tonight to see who I bought it from.
« Reply #53 on: December 10, 2017, 07:54:41 PM »
I found them, seem to be UK based. Spendy too......
Thanks for the info!
Offline bryanp
« Reply #54 on: December 11, 2017, 10:41:02 AM »
Definitely spendy, but the guy who provided the supercharger uses it on his motors for dialing-in the psi.
Offline bryanp
« Reply #55 on: April 02, 2018, 05:38:45 PM »
Slowly, but surely, incremental progress.  New front suspension; Spax adjustable coil-overs and Minisport ventilated brakes.   I bought a Series II E-type coupe last summer and vowed not to work on it until the Mini was complete . . . one new heater valve and clutch master cylinder later . .. .
Offline Willie_B
  • CREW
  • 1380cc
  • Total likes: 44
    • Lilburn, GA,
« Reply #56 on: April 02, 2018, 05:46:40 PM »
I was thinking something was missing in the photo, read back and noticed coil-overs.
« Reply #57 on: April 02, 2018, 07:02:38 PM »
I also have a Series II E-Type coupe, tell us about yours........
Offline bryanp
« Reply #58 on: April 02, 2018, 08:01:57 PM »
Before I get to the Jag, I noticed something odd w/ the new hubs.  After torquing down the swivel pin nuts at the top and bottom of the hub on the left side, it swivels easily and I can turn the rubber dust covers at the ball joint w/ my fingers.  But on the right side - same procedure - I have difficulty swiveling the hub w/ two hands.  Same torque setting (30) and I can also turn the dust covers w/ my fingers.  I haven't lubed the top and bottom zerks, I feel like I shouldn't need to to get easy swiveling.  I'm talking about rotation in the vertical axis, not the rotation of the rotor.
Anyway, the Jag; I bought it from a doctor in Orlando who had it since 86.  I have a FL certificate that shows it was off the road/unregistered for nearly 20 years.  It only has has 38,700 miles on it.  About 5 years ago he started doing a lot of work - rust repair, dynamat, painted from primrose yellow to black, new tan interior, stainless exhaust, new AC from Vintage Air, conversion from the two Zenith Strombergs to the triple SUs, alum radiator, electronic ignition, etc.    I bought it knowing that it had mechanical needs and I didn't want to spend money on a project that needed paint/interior.  The engine runs strongly, but the long-term storage maladies showed up right away.  Coolant geyser out of the heater valve  (had to cut it off w/ a dremel), and the third time I drove it, I wondered why my foot kept slipping off the clutch pedal . . . .   Also, the clutch is completely spent - no more adjustment at the slave cylinder, even after cutting about 3/16" off the rod - no play in the throwout bearing lever at all.
Here is a pic - looks fantastic from 15 feet - but it needs to be pushed!
« Last Edit: April 02, 2018, 08:04:49 PM by bryanp »
Offline bryanp
« Reply #59 on: April 02, 2018, 08:03:26 PM »
Dave - I just noticed your '69 in your footer.  Mine is April-ish '70.
« Reply #60 on: April 02, 2018, 08:58:18 PM »
Wow, my car was originally primrose too, and guess what color it is now?   ;D
I also got rid of the Strombergs, but couldn't afford the triples, so I have 2 SU's, still ran better than with the Strombergs.
No A/C in mine tho, although I did add electronic ignition. I also removed the side marker lights, I just didn't like them, they looked tacked on
« Last Edit: April 02, 2018, 09:03:13 PM by MiniDave »
Offline bryanp
« Reply #61 on: April 03, 2018, 08:35:25 AM »
haha - great minds . . . .
I like the quarter light deletion!
At the risk of turning this into Jag-chat, I am also thinking of a body mod.  I think the Series II is mechanically superior to the older, better looking E-types, but I really dislike the rear taillight-valence treatment of the S.II.  It looks to me like the curvature of the lower taillight arrangement of an Audi Q5 would work, tucked just under the bumpers of the Jag.    The rear quarter lights would also be deleted.
Anyone have any bright ideas about my hub recalcitrance before I go disassembling it?
« Reply #62 on: April 03, 2018, 10:49:06 AM »
Use the Audi tail light to make a poster board (cardboard - aka: CAD from Project Binky) template to check the match of the curves?
Offline bryanp
« Reply #63 on: April 03, 2018, 02:46:56 PM »
Yes; that is the plan.  I don't really do metal work - at least I don't think I do it very well, especially on a compound curve beauty like this.  I live about 45 minutes from the low-rider capital of the world in Espanola, NM.   I know some of those guys - magicians w/ metal.  When the time comes, I might take the car up there to see if they might take it on.
First things first, though.  MUST FINISH THE MINI
« Reply #64 on: April 03, 2018, 04:29:20 PM »
Re: your hub, if I understand you one side is difficult to turn left and right? You shimmed the ball joints correctly?
 like the look of the Audi tail lights if you can make them work.
I didn't like the looks of the splayed exhaust, so I tucked the center panel and lic plate up higher and used the earlier exhaust twin resonator pipes.
« Last Edit: April 03, 2018, 04:32:22 PM by MiniDave »
Offline bryanp
« Reply #65 on: April 03, 2018, 05:26:36 PM »
The hubs came fully assembled as part of the disc brake kit from MiniSport. .. .  I wouldn't think they would make that mistake.
I like your tailpipe solution - the license plate could easily be 3" higher on the S.II.
« Reply #66 on: April 03, 2018, 05:58:58 PM »
OK, well some folks think a bit of drag is the right way to shim them, they def should not have any play in them at all, so I'd go ahead and drive it as is and see how it does in another 500 miles. It also may feel different with the weight of the car on them.
