Restoration-Mini
Technical Forums => Restorations => Shop Tools And Equipment => Topic started by: 94touring on March 06, 2018, 07:06:34 AM
Title: Diy alignments
Post by: 94touring on March 06, 2018, 07:06:34 AM
In the coming months as I get cars back on the road with all my fancy adjustable suspension, I'll be doing a little explanation how to use tools for the job.  I've always set toe myself but have now bought a camber/caster tool. For toe I bought some metal plates with slots to pull a tape from to make the job easier.  For now here's a picture of what I'll be using for camber and caster.
Title: Re: Diy alignments
Post by: MPlayle on March 06, 2018, 08:22:01 AM
I will be needing to do the same very soon - have the fully adjustable suspensions front and rear on the Moke.
What plates did you get and where did you get the castor/camber gauge from?
Post by: MiniDave on March 06, 2018, 08:26:47 AM
Looks like he got it from Joe....   ;D
Post by: 94touring on March 06, 2018, 08:39:11 AM
Joes on eBay, $117 shipped.  There are others in the $200 plus range with electronic functions.  I watched some YouTube clips explaining how to do it with a protractor and painters tape marked out on the floor to set caster.  Alternately you can buy very expensive wheel plates that allow you to set the required 20 degree angles, but for the money a protractor is what I'm going with. The camber is very easy to set.  This also has magnets to mount to the wheels.  However I'm thinking I may fab up a piece of metal to adhere to the wheel center to mount this tool flush properly. Flat floors are important as well, at least not ridiculously unlevel.  For toe the plates were very basic and came with 2 tape measures. Each plate sits flush against the outer face of the wheels and the tapes are pulled and read.  I probably could have bought some plate and made my own but ebay was too easy. I will use these same plates in conjunction with the protractor to tape out 20 degree lines for the castor.  The main benefit being not having to find a place to set up our minis and being able to adjust and tweak several ways to suit your own taste.  I also have my rx7 to setup. All in all it pays for itself quickly and gives a lot of flexibility to try different setups.  As with all settings the car should be allowed to settle and rolled around to get accurate readings.
Some instructions:
https://www.joesracing.com/rt-4621-joes-caster-camber-gauge-instructions.html
Post by: Rosebud on March 06, 2018, 11:15:38 PM
Quote from: 94touring on March 06, 2018, 07:06:34 AM
Coincidentally, I'm adjusting toe angle tomorrow morning using the plate & measuring tape method. Question: How do I know if my wheels are pointed perfectly straight before I begin adjusting the toe angle? I was planing on simply making sure both left & right steering tie rods were of equal length. Is this foolproof? Is there an easer or better method?
Post by: Willie_B on March 07, 2018, 06:36:56 AM
Center the steering rack/wheel using the locating hole in the rack. Then work out from there.
Post by: MPlayle on March 07, 2018, 10:41:50 AM
Ordered a complete kit (toe plates, tape measures, caster/camber gauge) from JEGS for about $171 shipped free.
For the Moke, I will try using the "string method" down each side to zero each wheel to center then use the plates to set toe equally between each side.  I plan to try using some cheap vinyl tiles with a little grease between them as the slide plates.
Post by: 94touring on March 07, 2018, 03:14:23 PM
Guys on YouTube used trash bags folded over with wd40 sprayed between them.
Post by: Rosebud on March 07, 2018, 10:36:47 PM
Quote from: Willie_B on March 07, 2018, 06:36:56 AM
The locating hole would be behind the cover underneath the carpet, adhesive and Dynamat I'll bet. Dang.
Post by: John Gervais on March 09, 2018, 08:13:50 PM
Sounds like a nice kit from JEG's - could you post a link?
I 'made' some turning plates from a couple of polycarbonate squares with grease between them.  They work ok, but the tires can 'walk' off-center.
Post by: MPlayle on March 09, 2018, 09:13:42 PM
Here is the link for the kit I ordered.  Kit is supposed to be delivered on Monday.
http://www.jegs.com/i/JEGS-Performance-Products/555/81680K/10002/-1 (http://www.jegs.com/i/JEGS-Performance-Products/555/81680K/10002/-1)
Post by: Rosebud on March 13, 2018, 07:37:37 PM
Quote from: MPlayle on March 09, 2018, 09:13:42 PM
I have that same kit and used it for the first time the other day to first, screw-up my alignment. Then, after taking my car to a Mini-Savvy alignment shop to set things right, I tried using the kit to replicate and verify the shop's settings. Seemed straightforward enough, especially for measuring toe adjustment. Yet, the readings I'm getting from the kit are nowhere near the settings printout from shop.
Perhaps there's some technique involved that I'm not understanding. I do know that the smaller the wheel, the greater degree of error inherent in the kit for toe adjustment. Our 10-inchers are about as small as it gets. Maybe that's where the problem lies.
Post by: 94touring on March 13, 2018, 07:39:49 PM
Did you allow the car to settle and roll it forward and backwards?
Post by: Rosebud on March 13, 2018, 07:51:58 PM
Quote from: 94touring on March 13, 2018, 07:39:49 PM
Yes, I did. Up, down, left, right and every which way. Settling didn't alter any of the readings, and floor level is not a factor. The method the kit uses for toe adjustment is very straightforward and seems like it would be foolproof. Alas, my readings were way off. I'll shoot and post a video of the procedure tomorrow. Maybe someone will notice what and if I'm doing wrong.[size=78%] [/size]
Post by: MPlayle on March 13, 2018, 09:33:47 PM
I think part of the trick is to get the toe plates centered on the hub so that one end is not further from the hub than the other.
I also plan to "zero" each side relative to the body using a string running the total length of the Moke.  Then I will adjust each side relative to the string and compare across the car for confirmation of total toe.
Post by: 94touring on March 14, 2018, 11:17:34 AM
I just played around with these plates. I tried several variations on plate and tape placement.  These plates have an indent in the center to align them up with the hub.  I used that initially with the tapes placed in their appropriated notches. I got it set to 1/16 toe out. Then I moved the tapes to the top of the plates and ran them as close to the tires as I could, and noted still 1/16 toe out.
Post by: Rosebud on March 14, 2018, 11:55:24 AM
Quote from: 94touring on March 14, 2018, 11:17:34 AM
...then I moved the tapes to the top of the plates and ran them as close to the tires as I could, and noted still 1/16 toe out.
I did all that and was still way out on toe according to the alignment shop Seems pretty straightforward though, right? Although I understand that the smaller the wheel, even the tiniest of errors would be magnified. Sounds like you might have things dialed in correctly. Now that you've got the toe set, it would be interesting to have an alignment shop double check, but that would be defeating the reason we bought the plates in the first place; to save money by doing it ourselves. Good luck!
Post by: 94touring on March 14, 2018, 12:06:37 PM
How far out was your toe vs the alignment shop? I've always used a tape measure but this is the first time I've used plates.  This is way easier.
Here's some more fiddling to figure out a nice setup to do camber and caster.  These plates will be too long for me to turn the wheel in, but this is what I'm shooting for.  Bolted a piece of plate steel, used bungee cords to holds the main plate snug against the wheel face.  Drilled a sight hole to align with the hub, using a long bolt and spacer to feed the bolt through straight.  This should work pretty well once I get the proper sized plate.
Post by: Shrimps on June 12, 2018, 11:42:19 AM
For toe I scribe a line down the middle of each tire all the way around then measure the distance between the two lines on the front of the tire and compare to the distance on the backside of the tire.  I have an old curtain rod screwed to a couple 2x4 blocks with screws attached to each end that have been ground to a point.  The curtain rod allows adjustment to get the tool to line up exactly with the scribed lines on one side to measure against the other side.
Sometimes I don't get things adjusted quite right to have the steering wheel centered when driving down the road so I'll have to go back and adjust.  Otherwise it seems to work pretty slick.
And I park each tire on essentially two squares of cereal boxes with the shiny sides facing each other to allow for easier rotation of the tires compared to being on concrete when making adjustments.
Post by: BruceK on June 12, 2018, 05:16:08 PM
Quote from: Shrimps on June 12, 2018, 11:42:19 AM
Wait a minute.  Why wouldn't you just unbolt the steering wheel and center that?  Isn't that easier?   Or am I missing something?
Post by: Willie_B on June 12, 2018, 05:36:01 PM
If the rack & steering shaft are not centered the turn signal cancel cam will be out of position. Will not cancel in one direction if it too far out.
Post by: Shrimps on June 12, 2018, 06:23:04 PM
Quote from: Willie_B on June 12, 2018, 05:36:01 PM
That and you can have a more finite control of centering the wheel vs moving one spline to another (which can end up being quite a bit depending on how close you want to get it centered).  I'm kinda OCD about some stuff.
Post by: BruceK on June 12, 2018, 06:40:34 PM
Makes sense.  Thanks for the explanation.
Post by: John Gervais on June 12, 2018, 07:41:18 PM
Mr. Calver is sending this to me as soon as he can find a box and some bubble wrap:   4.gif
Post by: MiniDave on June 12, 2018, 07:47:20 PM
Cool!
What is it?
Post by: John Gervais on June 12, 2018, 08:03:48 PM
The classic Dunlop (AGO35) alignment gauge.  I bought it online, but because the seller wouldn't ship it to Denmark, I had it delivered to his mate's garage.  Keith picked it up from there and is sending it to me.
Post by: 94touring on June 12, 2018, 08:30:52 PM
I was going to guess the guts out of a classic pacman arcade.
Post by: MiniDave on June 13, 2018, 08:09:57 AM
The problem I have with trying to do home alignments is that my garage floor is neither flat nor level.
Post by: 94touring on September 21, 2018, 07:16:36 PM
Played around with my alignment tools today.  First time messing with adjustable lower arms.  Went very well, aside from a lot of fine tweeking to get it where I wanted. I have a better feel for how much adjustment effects camber now however.  One thing to take into consideration when doing toe or camber is to move the car and turn the wheel left and right so the suspension settles into place.  I still need to set caster and rear camber.  I figured I'd check rear toe to see how accurate aftermarket subframes are, and it was right at 1/16 toe in as it should be.
Post by: joakwin on September 25, 2018, 04:33:12 PM
https://www.wheelalignmenttools.com/product/2-wheel-alignment-system/
This is the kit that i got 2 months ago but I haven't used it yet, I'm getting close to the point of being able to use it on the mini
