Restoration-Mini
Classifieds => Parts for sale/wanted => Topic started by: gr8kornholio on March 07, 2017, 04:31:58 PM
Title: R/H gas tank
Post by: gr8kornholio on March 07, 2017, 04:31:58 PM
Looking for a right hand gas tank.  Wont be used as a gas tank, so rusted or has holes or dented is ok.
Title: Re: R/H gas tank
Post by: BruceK on March 07, 2017, 04:44:35 PM
Quote from: gr8kornholio on March 07, 2017, 04:31:58 PM
Okay, I'll bite.   Secret smuggling compartment?    Toolbox?
Post by: gr8kornholio on March 07, 2017, 05:58:45 PM
Nope, I'm a music nut, and really miss tunes when I'm in the mini.  Want to make it a sub box.  I've seen people try and make fiberglass molds and such, but I hate working with fiberglass.
Post by: gr8kornholio on March 07, 2017, 07:58:01 PM
I'm guessing these are fairly rare, did they only come on dual tank cars?
Post by: 94touring on March 07, 2017, 08:03:02 PM
Hard to find and usually pretty pricey for a sub box.  Myself I have an amp under my seat and two 6x9's under the rear bench and two 4" speakers on the dash. The 6x9s already had the wood cut for them when I bought the car, but sound pretty good on the low pass range from the amp. Otherwise I'd suggest a slim/compact subwoofer that has the amp built in. I have an 8 inch low profile sub/amp in my rx7 and it pumps some serious base. Would fit perfectly under your seat.
Post by: gr8kornholio on March 07, 2017, 08:08:15 PM
Yea, I figured they might be.  I have a 10" shallow sub behind the seat of my reg cab 85 toyota pickup.  May just have to bite it and do a fiberglass form to the right side to save as much boot space.  I have considered seeing what I could fit under the seat area.  Spare tire well is another consideration, but then running around without a spare.
Post by: MiniDave on March 08, 2017, 06:12:35 AM
Interesting idea, why not just build a tank shaped enclosure? If you want to complete the illusion, they sell "fake" right side gas filers
Post by: gr8kornholio on March 08, 2017, 06:45:33 AM
That's the back up plan.  Was hoping the r/h tank was used more than just on a cooper s, but in my digging I'm thinking it wasn't.
Post by: BruceK on March 08, 2017, 08:10:14 AM
It was only an option on the Cooper S.    But there were (and are) non-OEM right hand gas tanks out there.
Post by: MiniDave on March 08, 2017, 08:40:10 AM
If you look around you might find an old rusty R/H tank, but they're spendy enough that it's worth it to just fix it.
£277 plus shipping from the UK for  a new one..... http://www.minispares.com/product/Classic/Body/Panel/Fuel_Tanks/21A2183.aspx?030708&ReturnUrl=/search/classic/right hand tank.aspx|Back to search (http://www.minispares.com/product/Classic/Body/Panel/Fuel_Tanks/21A2183.aspx?030708&ReturnUrl=/search/classic/right%20hand%20tank.aspx%7CBack%20to%20search)
If you  build an enclosure and just want the "look", you can buy this for only $25 plus the cap....
(https://www.minimania.com/images_temp/800600001msa1126.jpg)
https://www.minimania.com/part/MSA1126/Austin-Mini-Twin-Gas-Fuel-Tank-look-Filler-Neck (https://www.minimania.com/part/MSA1126/Austin-Mini-Twin-Gas-Fuel-Tank-look-Filler-Neck)
Post by: MPlayle on March 08, 2017, 08:42:31 AM
There used to be an outfit in Australia making fiberglass replica right hand tanks for a bit less than the steel ones.
Post by: gr8kornholio on March 08, 2017, 09:27:24 AM
Not to worried about the look of dual tanks, just figured it'd be most efficient use of space on that side.
I'll search around the Australian sites and see what pops up.  I need to order my wing window seals from over there too.
